MNBlizzard
I know this has been an issue with others here. First time for me this morning, I went to turn over and the starter just clicked. The battery is good. I pulled the airbox off and put the blow comb to the relay next to the battery and two minutes later it fired right up. Now, I would like to fix this but am wondering if I could put silcone on the top where the terminal go or if I should pump each chamber full of dielectric grease. Does Yamaha have a cover for this relay? Any thoughts?
Convert
- Apr 14, 2003
- Lakeville & Nevis, MinNoSnowta
This has happened to me twice also when I get a little snow in there one day and it sits outside on a really cold night. Would also be very interested in a fix. I generally keep them in a warm garage so not a huge issue but there are those times
MNBlizzard
Ah, a warm garage...now that would be nice! I think I may try some silcone on top of the leads into the switch. I have no idea what causes the failure but I suspect moisture is the culprit. I guess it may be a just try it and see what happens.
Mikey
- Thunder Bay Ontario
- 03 RX-1
Carry a jumper wire so that you can start it and when its started the engine heat will dethaw it...
MNBlizzard
Mikey said:Carry a jumper wire so that you can start it and when its started the engine heat will dethaw it...
Mikey
- 03 RX-1
Guess I shouldve made myself a lil clearer. It will so if you bypass the relay cause I have done it before. The two terminals on the top of the starter relay just join them together til it starts. I am not talking about boosting the battery.
Thats why I said jumper WIRE and not booster cables.
