yamahaguy
Ride SAFE
- Apr 20, 2014
- 2015 Yamaha MTX LE with MPI
Ready for the weekend!
ViperBill
Yea, heading to iron river wi sat morning. Sure glad to not miss a weekend. No snow here trailering every weekend so it sucks to brake down. oh well at least it was towards the end of our ride. Made for a long ride home.. S@#t happens!!! Like we always said If you aint braking it you aint riding it!
Turns out when they got it apart the chaincase had several ears broke and lost the lube and completely destroyed the case and everything in it! We have a really good dealer and they will have ready tomorrow. Any sled can have a problem its the dealer that makes the diference. Thats when you know you are dealing with a good company!!!
So whos your dealer? Give them a plug they deserve the praise for the great service they gave you. Also you will get updated parts so better than new.
yamahaguy
Ride SAFE
- Apr 20, 2014
Whats been updated parts wise?So whos your dealer? Give them a plug they deserve the praise for the great service they gave you. Also you will get updated parts so better than new.
ViperBill
Waldoch sports in forest lake mn. Over the years I have bought 4 new bikes, a trailer , generator and this is my first yamaha sled. Always been treated very well. No complaints and refer to them every chance I get.
Yamadog
Waldochs are a great group of guys I have bought several sleds there.
Tabs are twice as thick on new ones. Different gasket. If oiltank is leaking the tank has quite a few differences including no more sightglass,different baffle and screen and more oil. The late 15's had all this.
yamahoor
- Jan 4, 2015
- 2015 viper xtx
Interesting stuff. Turns out there were a few stripped gears and bent the shift fork . I didnt talk to the mechanic directly and the service dude couldnt explain why this happened. I just hope its ready for friday i have holidays booked for ridin lake of the woods for ten days
jlevandoski
- Dec 11, 2014
- Connecticut
- 2014 Yamaha SR Viper XTX SE
Sorry for this being a little late, but the chain case is not Arctic Cat. It's a Yamaha designed unit, the same one that comes off of the Apex. It was one of the 70-something additional updates Yamaha did to the SR Viper before it entered production.
ViperJim34
- Dec 17, 2014
- Blaine,Minnesota
- 2015 sr viper rtx se
Brian the mechanic there is a good guy. He will treat you right
DranttelSS
TY Advertiser
- Oct 9, 2014
- St. Peter MN
- 2007 Yamaha Attak
The Chaincase is nothing like the Apex. Yamaha may have made some improvements, but still not an Apex case.
TD Max
I wonder who designed the oil tank? And is it same as the Cat 4s machines?
yamahaguy
Ride SAFE
- Apr 20, 2014
I agree
yamahaguy
Ride SAFE
- Apr 20, 2014
Oil tank looks just like cat also. Not sure who's idea it was to change from sight glass to dip stick and use more oil? The tank dimensions are the same.
silver rocket
Cat problem. They have problems with the jackshafts. The jackshafts are to soft. The splines will start to wear and than will make a small grove and the gear will no be able to slide all the way into the other gear. The fix is a stronger jackshaft. They were suppose to have a better jackshaft for 2015. You probably have the same jackshaft. Also there is to much play between the top gears. You can add a .030 shim behind the top gear and will engage further into the other gear. How do I know this? I ride a boosted cat. I installed a Belanger racing jackshaft, manual chain adjuster and Hyvo gears and chain on my 2014 10,000 klm ago.
