RX-1snow
My exaust tips are black with soot and it runs down the silver outer rim staining it , practically after every trip.
Does this indicate too rich?? I have stock jetting completely but do have the green holtzman springs. I ride at sea level.
Could these springs cause this?? Anyone else have this happen?
Buckeye
- Lakes Region, NH
Not necessarily. Most of it comes out at warmup and idle. Once warmed up and running you won't leave the black stuff.
RX1 Yooper
That's normal. I added chrome auto tail pipe extensions that protrude 2 1/2", and solved the problem.
Yooper , can you post a pic of your exhaust extensions ?
Where did you get them or did you make them .
I hate the black shi! on the tips, I was going to paint mine black
Ger
Ger
Mighty
- Apr 17, 2003
- Grand Ledge Michigan USA!
- 22 Mach Z
23 Sidewinder SRX
Perfectly normal, that's Precisely why they are black for 04.
ski-bum
If they turn a tan color, you are too lean. If they turn black you are just right. If they turn black and drip black all over your tunnel extension then don't ride in the rain.
No...its normal. :wink:
1xr
I think it's oil that these things burn, messy like a diesel.
scottr37
- Aug 17, 2003
Are you using premium octane fuel? Try using a tank of regular 87 octane. Burns much cleaner. No need for the extra octane, unless you're using different cams or a turbo.
1xr
Nope regular fuel.
treewhacker
Where do you guys get the idea black is normal? Tan is the color of a normal burning 4 stroke. If it's black you're too rich or burning oil, and neither of those is normal.
SIMMER
You CANNOT determine how an engine is running from the exhaust tips!
Mine are also black but my plugs are a perfect toasty brown and my sled runs like a champ!
RX1 Yooper
RX1 Yooper
ger,
I couldn't post the picture, so post your email address, and I'll send some.
Carston
Carston
