I have a VERY well used piece of hose I use to remove and install spark plugs, but is alot shorter than the one in the picture. Cut a piece of hose just long enough, I have several one for crotch rocket motorcycles that is very long and one very short for Nytros. Short one gets most use.
Hey guys Your working to hard at this one. I just experienced this yesterday on the trail with a bunch of guys standing over my sled replacing the 3 plugs on my viper. Yes your right the 3rd plug don't come out attached to the tool provided by yamaha. As we stood there on the trail figuring how to get the final plug out one guy said unscrew the plug almost completely and then stick the coil in and snap it on the plug un turn it slightly and pull the plug out. Worked like a charm.. Did the reverse putting plug back in.. Hope this helps everyone. No special tool needed.
The plug socket that comes with the kit will work when you get the plug just about out push it down over the plug until it botTom's out and it will clear the tank
