alexyamrx1
I guys! I run a apex mountain MPI stage 1,my drivers slip all the time??? i put NEW (WAHL) Anti Ratchet Drivers! and after some ride it slip again!any body have solution for my? my track is very tight and slip yet! my track is 159x15x2.25 / 2.52 pitch my suspention is a ZX2 AD BOIVIN! with (WAHL) Anti Ratchet Drivers 9 tooth 2.52 pitch thanks guys
Modedmach1
- Jul 28, 2012
Avid drivers are by far the best. Not cheap but, they are worth it.
Accentstripe1
sprocket
X2 I smoked my Wahl drivers halfway through the season last year. Avids are expensive but imo the best
givemeaboost
- Dec 5, 2003
- Great Falls, MT.
- 03 Rx1 Turbo
- Great Falls,MT
If you need 8 tooth 2.52 pitch drivers you'll have to stay with the Wahls. Avid doesn't make them.
Ken.........
Ken.........
![](/styles/TYLifeMember.gif)
![](/styles/vip.gif)
nate007
- Dec 25, 2006
- Iowa City, Iowa
- 1. '06 Apex -twin screw
2. '04 Redline Revolt 800
3. '09 Nytro XTX - twin screw
Please add your location to your site profile, thanks!
If you're only running a stage1 and slipping your drivers, I'm wondering if you have something else going on with your rear suspension that would cause that to happen so quickly? I don't know much of anything about the ZX2, but I wouldn't think that the power level of a stage1 would do that?
Maybe I'm wrong, but does that sound strange to anyone else?
alexyamrx1
Thx i got new Avid and they work magic!
By the way i added my location and a signature.
Thx for the reply
Thx for the reply
ghost rider
Suspended
- Nov 13, 2013
- Muskoka, Ontario, Canada
- Rxwarrior
- Muskoka , Ontario
nate007 said:Please add your location to your site profile, thanks!
I had this problem with my zx2...the fix was to tighten the track so there is a 1" sag.
At outside temp.
Or if you store in a heated garage at 72 degrees there would be zero sag.
I haven't had the problem since and I run stock drivers and 10 lbs boost.
alexyamrx1
I guys my AVID drivers are striped on the shaft ??? (tabarnak) any body have a other solution for me thanks.
kinger
Yikes I think you got the best! Something must be a miss. I have run Avids and 10-11psi stage 1 apex on a 151 and not a single issue.
Sorry I am not much help.
