Phatboyc
- Apr 2, 2007
- Ottawa, Ontario
- 2022 Sidewinder
If you only ride in Cochrane speedway trails it doesn't count. Squeak needs moguls and warm weather.Permatex Teflon spray! Sprayed the sway bay bushings a year ago still no squeak! 16 viper same thing ,lasts awhile!
Ok I'll try this one and see.
Phatboyc
- Apr 2, 2007
- Ottawa, Ontario
- 2022 Sidewinder
Cause so far I have used silicone spray and this Ipone. Put a test sample in the freezer and didn't freeze so I like it. Just didn't last.
DennyTuna
- Jan 28, 2017
- Ohio
- 25 Winder LTX LE w/EPS
18 Winder LTX LE W/EPS
97 SX Vmax 600
When you break a sway bar they don't squeak...ha! I spray fluid film on the bar and again I don't have squeaks.You guys with Mainway greasable bushings. Your saying your sway bar bushing doesn't squeak?
mike800
- Jan 20, 2022
- Anoka County, Minnesota
- 137" Catalyst
Not that I could ever tell.You guys with Mainway greasable bushings. Your saying your sway bar bushing doesn't squeak?
earthling
- Dec 1, 2017
- 2021 SRX
2006 ATTAK
How loud is your front end that you can hear it over the kubota imitation the primary is doing?You guys with Mainway greasable bushings. Your saying your sway bar bushing doesn't squeak?
Phatboyc
- Apr 2, 2007
- Ottawa, Ontario
- 2022 Sidewinder
That's what I call my Vector. My little tractor that could!
Considering by the time I finish a snocross ride, I can stop the engine and sway left and right with my weight on the running boards and its doing it. So loud enough that a machine of this $$$ class shouldn't do it.
DennyTuna
- Jan 28, 2017
- Ohio
97 SX Vmax 600
Stop doing that. There I fixed your Squeaking problem.I can stop the engine and sway left and right with my weight on the running boards and its doing it.
WinderFab
- Mar 1, 2009
- Woodbridge, ON
- 2020 Sidewinder Ltx GT
Lol..Stop doing that. There I fixed your Squeaking problem.
fxnytrortxkid
- Apr 19, 2007
- Rensselaer, ny
- 09 nytro rtx
I will add that my sway bar links squeak and so does the upper ball joint on the spindle in upper a-arm. I hit them with a Teflon spray lube cpl times a year.
