Stinson
At about 1,700 miles the front end started to squeak. Wondering if anyone else has this on their sled? I run about 65psi in the shocks and admit I have not checked them in a while. When I push down the front I can recreate the squeaking coming from the front shocks. Any suggestions to correct this?
sk-rx1
I had a sqeak with the std shocks. Looked around, sprayed some WD 40 on the sway bar and links, squeak gone. Might check that.
csederlund
- Oct 7, 2012
- Frederic, WI
- 2014 LTX SE
I have the same squeak, but I don't think it is coming from the shocks. I will try the wd 40.
Yamacat21
I had my float 3's replaced at 1500 miles and still have a squeak in the front end. Don't think it's shocks, I do think its odd that there are no grease points on the front of this machine.
RXVIPER
- Mar 4, 2010
- Shelburne ,Ont
- 2014 SR Viper LTX
2003 RX-1
Squeak is coming from the suspension A arms and the upper ball joint. A little lubrication and all will be gone.
freelance
- Apr 15, 2013
- Manitoba, Canada
- 2014 Yamaha SR Viper XTX SE
My brakes started to squeak around the 1700 mile mark but that's all I've heard.
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
Also there might be some noise coming from the steering joints in the nose. Pop off 1 tie rod boot and lube.
Stinson
Talked to my dealer today and he also thought it was not the shocks themselves. I will take a closer look this weekend and lube some of the parts and see how that does.
loudelectronics
- Dec 1, 2007
- Souris, Manitoba
- presdwr.spaces.live.com
My dealer pdi's the front end with lithium grease. No noises.
Nytro40th
- Sep 19, 2007
- Amherstview Ontario
- 2014 SR Viper RTX SE
lithium grease worked well on my nytro as well, prolonged the ball joints.
kylechargerrt
- Dec 8, 2013
- Scotland Ontario
- 2017 YAMAHA SIDEWINDER LTX-LE
1998 MACH-Z
Spray or Inject some grease up under the joint right below the shock make sure to get it up under the boot then spray the rest of the joints down with white lithium grease. Worked for me took a couple miles for the grease to work in and the noise has not been back since... This was 2000miles ago.
