tpayner19
Replacing my Y-Pipes on my 06 Apex. I removed the y-pipe bracket that is riveted to the tunnel. Should I just rivet it back or stainles steel bolts and nuts (I giggled when I typed "nuts")? a couple of the rivet holes are enlarged. Should I drill those out and used bolts on just those?
Thanks.
Todd
Thanks.
Todd
70superbee
I used stainless button head bolts and nylock nuts. The rivets will just wear again and make the holes bigger.
tpayner19
No problem with the "ny" in the nylock melting?
CaptCaper
- Jan 1, 2007
- Northern N.H.
Use Blue Loctite. Works well with SS and new bolts.
70superbee
No I have not had any issues with them melting, and yes blue loctite makes sure they stay tight.
Richie R
Richie R
