yamanytro121
Just wondering if the engine needs to come out to replace the starter on an 09 RTX SE or is there a easier way.
toyota4runner
Not tryin to be an #*$&@ but make sure you check your relays before you get too deep
yamanytro121
checked everything and it all checks out fine.. its a brand new relay.
yamaha1973
- Nov 27, 2011
- St. Peter Minnesota
- 2014 Viper XTX SE
hows the battery? what are the symptoms?
yamanytro121
batterys good. brand new relay. when i turn the key to start position it loads up the starting circuit and drains the power to the dash if you hold it for more then a second.. i can hear the solenoid clicking and working like its spose to. got the CODE 12 appaering on the dash but thats only from the key being turned to the start position without the sensor sensing any movement in the engine. put and amp clamp on the supply to the starter and there over 500 amps being supplied. engines not locked becuase i can turn it over with my hands.
I checked through all the electrical to make sure that harness is in good shape and it is. pretty well narrowed it down to the starter.
Did you try running power directly to starter with jumper cables?
yamanytro121
pulled the starter off and the startor is toast
Apex2006
- Oct 26, 2009
- McHenry, IL
- Yamaha Sidewinder SRX-LE 2019
Yamaha Sidewinder XTX 141 2017
Yamaha Viper XTX 2015
Yamaha Sno Scoot 2018
Ski-Doo Renegade XRS 850 2020
How difficult was it to remove? When I changed the oil today it looks like it is very excessible up past the oil filter but have never removed the starter.yamanytro121 said:pulled the starter off and the startor is toast
yamanytro121
it wasnt to to bad actually. had to remove the oil filter and the front mounting bolts then just pried on the engine a little bit and a buddy wiggled it out... deffintly need a buddy there though. its not possible to get it out with out the front mounting bolts out and a little bit of help from a pry bar
Apex2006
- Oct 26, 2009
- McHenry, IL
yamanytro121 said:it wasnt to to bad actually. had to remove the oil filter and the front mounting bolts then just pried on the engine a little bit and a buddy wiggled it out... deffintly need a buddy there though. its not possible to get it out with out the front mounting bolts out and a little bit of help from a pry bar
Thanks! Good to know if I ever have to replace it. How many miles on your sled?
yamanytro121
6800km. first issue iv had with it. im pretty impressed with it thats forsure.
yamanytro121
Hey just wondering if anyone out there knows if a starter from a apex will fit on a nytro. the part number on the apex is a 8FP-81890-00-00 and on the nytro its a 8GL-81890-00-00. wondering what the first 3 letters/number represents.
Wondering this because my buddy with an apex has a spare starter and if they are the same then im gonna use his and buy him another one that way i can be on the snow a little quicker.
Thanks for the info
Thanks for the info
Supa Dexta
