Thornton3280
- Dec 30, 2021
- Sobieski wi
- 07 yamaha phazer base
Easiest way to tighten the starter bolts. Phazer cranks over pretty slow threw a new battery with 310cc amps still slow. Wondering how to go about checking and tightening the starter bolts. Prefer not to pull the front end apart if possible.
Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
You'll have to pull the starter to realign it and tighten the bolts. This thread does explain how to tighten them:
However, you do not need to remove the whole front end. Through the bottom, with the cover off, you will see a an aluminum bracket that prevents the starter from coming out. You can cut it off, it serves no purpose. It can then be taken out, easy peasy lemon squeazy. I've done it on 3 sleds, no problems.
Oil change,Front frame removal and starter removal Pics
Here we go.Will add more comments and titles later but here are pics as taken as job was being done.If just doing oil change you can stop after airbox removal.However I would recommend doing the starter also.I previously did mine and Loctite on bolts kept them both tight all year so it is a good...
ty4stroke.com
Thornton3280
- Dec 30, 2021
- Sobieski wi
So do i just take the skid plate off as if I was draining the oil? Then grind that aluminum ear 1/8 of an inch or can I go more? An unbolt starter and pull it out or do I have to loosen the subframe?
Mooseman
- Nov 3, 2009
- Greely, Ontario
- Greely, ON Canada
Yep, remove skid plate, cut the whole thing off with a Sawzall, unbolt starter and out it comes. Still have to move it around but it will come out. You'll see the bracket that I'm talking about. It mounts to nothing.
Thornton3280
- Dec 30, 2021
- Sobieski wi
Thanks Mooseman! By chance do you know the torque spec for the 2 bolts
Mooseman
- Nov 3, 2009
- Greely, Ontario
- Greely, ON Canada
Sorry, no. I just went with snug. Just don't go overboard since they are small.
And dont forget Loctite.
