N2DEEP
Not much luck with my new mtx, lost last weekend to loosing all the engine oil and now the starter just went for a #*$&@. From day one the starter did not sound right have to wait to see what the dealer finds. I know with 20 k into this sled and having to pull up to the boys ridding the wife's sled is getting pretty old, also having to carry a tow rop for a Yamaha ? Never had to do that before. SAD the sled has only 560 mi on it , oh ya and the tri-post steering bushing is pretty much gone already too. Get it together Yamaha
N2DEEP
Tricky Nick
Going Vertical
- Mar 23, 2014
- Eagle River, AK
- 2015 Viper MTX 162 Turbo
Back up sled AC M7
Non of this was warranty???
N2DEEP
Ya it's warranty. I'd be in jail right now if it wasn't
cacsrx1
Ouch.....
N2DEEP
If I thought that was a piss off my wife's sled is in the next bay with the same starter problem, motor on its way out. Double Ouch
cacsrx1
That's bad luck.....I thought I had it bad when my Apex blew up.If I thought that was a piss off my wife's sled is in the next bay with the same starter problem, motor on its way out. Double Ouch
katkiller
wintering in fl. bye bye snow!!!
- Apr 1, 2014
- NORTHERN MICHIGAN
- next sled poo voyager
78 ENTICER 340
WOW SORRY TO HEAR THAT
MAKE SURE THEY CHECK THE ONE WAY BEARING AND THE FLYWHEEL SURFACE.
WHEN I FIXED ONE AT MY WORK LAST YEAR THE TEETH NEVER WENT THROUGH THE MOTOR
BUT ALL THOSE PARTS HAD TO BE REPLACED.
P.S. THATS THE NEW YAMACAT ,I WILL NEVER BUY ANYTHING WITH A CAT PART IN IT OR ON IT .!!!
Tricky Nick
Going Vertical
- Mar 23, 2014
- Eagle River, AK
Back up sled AC M7
Seriously??? I dont see how this is an Arctic cat problem. These engines are delivered to Thief River Falls from Yamaha with the starter already on the engine. All Arctic cat is doing is installing them in their chassis.P.S. THATS THE NEW YAMACAT ,I WILL NEVER BUY ANYTHING WITH A CAT PART IN IT OR ON IT .!!!
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
IMO, and again, my opinion! The battery location, battery cable length, and ECU tuning is causing this. The extended cranking time to start is causing havoc. The battery voltage drops when cranking, below XXX volts, the fuel injection system no longer fires = continued cranking with no starting = starter & components wear & tear. Just my .02!
katkiller
- Apr 1, 2014
- NORTHERN MICHIGAN
78 ENTICER 340
the starter solenoid is arctic cat which I think is part of the problem also,i have worked on 75-100 nytro's and I have never seen this problem tricky nick!Seriously??? I dont see how this is an Arctic cat problem. These engines are delivered to Thief River Falls from Yamaha with the starter already on the engine. All Arctic cat is doing is installing them in their chassis.
Tricky Nick
Going Vertical
- Mar 23, 2014
- Eagle River, AK
Back up sled AC M7
Hmm. That is actually the best explanation I've heard so far. Definitely worth looking intoIMO, and again, my opinion! The battery location, battery cable length, and ECU tuning is causing this. The extended cranking time to start is causing havoc. The battery voltage drops when cranking, below XXX volts, the fuel injection system no longer fires = continued cranking with no starting = starter & components wear & tear. Just my .02!
Has anyone done a voltage drop test while cranking yet?
How about run a thicker guage battery leads?
Tomkat700
- Aug 20, 2014
- 2015 Viper MTX 153 T
Mine has always fired right up like normal, I also have the MPI kit so not sure if the GEMS controller has anything to do with that.
tapex_07
- Feb 15, 2009
'07 Apex RTX SC2 MPI 128x1
My MPI Viper definitely doesn't fire up like the Impulse Nytro! My Viper takes about 1 full sec of crank time to fire up nearly EVERY time. TOUCH the key on the Nytro and it fire instantly...
So the extended crank time, long leads with battery location, and ECU differences make sense to me.
stingray719
Yet both of mine fire right up even around 0 degrees. If the leads and battery were wrong neither of mine would fire right up, now that is not saying you can't have a bad battery even new.
