triplepower
I have an 06 rage and have issues starting it. Starts instantly all winter but issue is after it sits all summer, it just turns over forever and wont pop. Any suggestions at to do besides pulling carbs etc... Just want to get it started to put it on the trailer to take it to the dealer for service
radianguy
- Jan 1, 2007
The carbed 3 holer is like that!
I have an 08 Vector that's a bitch to start after summer storage. I've heard that it can be easier to start by pressuring the fuel system, ie, removing the tank vent and adding air, I haven't had any luck with it. Good luck with it!
Grimm
Yup, worked for me on my Vector. Follow the end of the vent/overflow line down the left side of the tank to where it clips onto the chassis frame near your left foot. Pop the line off and blow into it to pressurize the tank. Keep the air pressure up by pinching the end of the vent line. Then try firing up the sled.
Handy
- May 12, 2005
- Anola Manitoba
- 1983 Bravo, 1988 XLV, 1991 Pazer II, 2005 Vector, 2006 Apex Super Charged, 2017 Viper STX DX 137, 2018 SR Venture DX
This trick always works for me. Read about it in the RX section back in 05 and have used it ever since on my carbureted 4 stroke.
J1635
Suspended
- Aug 17, 2014
- Yamaha Nytro
x4 on the pressurization. ive seen multiple videos on the new Vipers not even starting properly unless the guy is blowing pressure into the gas tank. makes sense. Im pretty sure he even went as far as putting a little primer pumping line on his steering column, fired up Every time with it
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
Many times I just remove air box lid and choke carbs with a hand to get them to fire after summer storage.
thrasher
- Nov 22, 2006
- Ottawa Valley, Ontario
- 06 Vector RS ER
Just pop the air filter cover off and either use quick start or gasoline in a squirt bottle to spray in the carb inlets. Will get the engine going. May need to do a few times before the fuel pump primes the carbs.
straycat03rx1
- Aug 6, 2014
- t cats out the a$$ one rx1
Ive seen either used. Is that a bad thing?The sled fired right up .
Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
Quick start is not a good thing, espeically using it in this application where simply pressurizing the tank will do the trick. jmo
SAB1
- Mar 1, 2011
- Tuftonboro NH
- 2017 Sidewinder LTX SE
2010 Vector GT
2006 Apex
Yes pressurize the tank. I just remove gas cap, put duck tape over top of tank. Cut a small hole a stick clear tube in and blow into it while cranking engine
Dara
Easiest way is to blow into the line on the left side of the tank.
Crank as you blow on the tube and it starts right up.
I had an 06 Rage for 6 seasons. Its just the way they are, and you only need to do it once a year
sledjunk
- Aug 7, 2007
- Pefferlaw, Ontario
- 2015 Vector LTX 12141 KM
2015 Vector LTX 30736 KM
2012 Vector 20100 KM
2007 Vector GT 30638 KM (Sold)
My '07 Vector only started doing this in the last year or so. I have been choking the carbs as hibshman25 suggests. I came here today to look for a better solution and I like the idea of pressurizing the tank. Will have to try that this weekend.
RSVECTORFREAK
- Oct 28, 2004
- Chassell Michigan
- 2005 RS Vector ER
I'm one of those prestone starting fluid guys! I've been doing it every year since new! 9500 miles still runs like new. It takes very small shot in each carb while cranking. Don't by any means hold the sprayer down just a quick blip in each carb.
sledjunk
- Aug 7, 2007
Worked like a charm! Thanks!My '07 Vector only started doing this in the last year or so. I have been choking the carbs as hibshman25 suggests. I came here today to look for a better solution and I like the idea of pressurizing the tank. Will have to try that this weekend.
fastdave
- Oct 20, 2011
- Chippewa Falls, WI
- 2007 Yamaha RS Vector GT
What I do with my 07 vector is much easier. Open the hood and in front of the left foot well connected to the top of the frame tubing is a clear hose. It's the breather hose for the gas tank. I take a pliers to squeeze the hose clamp and pop that line off, then stick my compressor sprayer into it and shoot some air in. I quickly put my finger over the end of the tube to hold the pressure and hit the starter and away she goes. Then pop the hose back on and you're done. I've heard from others on this board that you can blow into the hose with your mouth if you want to.
