Moodeyblue
- Sep 16, 2003
- Alberta
- Sidewinder SE
Looks like my steering post is off like many others. What is the best way to adjust this? Is there a linkage to adjust the post, or do I adjust the linkage to the skis to center the post?
AXR
- May 5, 2007
- Central NY
- Current: 2017 SideWinder L-TX LE
Past: 2015 Sr Viper R-TX SE, 2008 Apex RTX, 2002 Sx Viper, 1997 XTC 600, 1991 Doo Formula Plus.
What do you mean? With the skis straight, are the bars turned? If so you have to adjust the tie rods @ the skis.
Moodeyblue
- Sep 16, 2003
- Alberta
- Sidewinder SE
yes, skis are straight and bars are turned slightly to the left. On other sleds, there is a linkage from the bell crank that can be adjusted. I don't see any adjustment on this unit other than on the tie rods to the skis...unless I am missing something?
Moodeyblue
- Sep 16, 2003
- Alberta
- Sidewinder SE
correction. skis straight and bars turned slightly to the right.
fast n furious
- Jan 24, 2010
- Nova Scotia
- 2008 40th anniversary apex LTX GT
Driving mine straight the bars are slightly off as well
orangecrush
- Oct 23, 2012
- 2017 Yamaha Sidewinder LTX LE
- Lino Lakes, MN
Mine too. Anyone got a solution?
saskattakman
yes take it to the dealer that did the pdi that's what you paid them for
orangecrush
- Oct 23, 2012
- Lino Lakes, MN
I would but like a lot of us, Yamaha dealers are far and few in between, 6 hour round trip when I could probably do it myself. If someone would tell me how?yes take it to the dealer that did the pdi that's what you paid them for
AXR
- May 5, 2007
- Central NY
You need to adjust the tie rods. The correct way is to remove the rubber boots and loosen the jam nuts inside the bulk head as well as the ones by the skis, then turn the rod. I think it tells you in the book? If not I know it does in your pdi packet. My dealer did it differently. They removed the tie rod end by the ski and then adjusted from there w/out removing the boot. I know that's not the right way, but I don't see the difference? Sure is a ton easier. Oh almost forgot to get to the jam nut behind the rubber boots you have to turn the bars all the way in the opposite direction of the side you are working on.
