Vice108 If you don't like the increased steering effort just soften the front up a couple turns on the preload. It doesn't take much to make a big difference. You will have less wear too.
I have an RTX with Fox floats on the front so I don't have a preload adjuster other then to change air pressure. I may try adjusting the transfer rod a little bit towards more transfer though. I originaly dialed in less transfer when the sled was new to keep the skis planted more. With the simmons the skis grip great so I may be able to increase the transfer a little bit. Perhaps it would help.
