I want to remove the apex sticker from the windshield of my sled without damaging the shield. has anyone done this and whats the best way of doing it? i tried to peel it with my fingernail like evry other sticker I have ever removed and i cant even get it started. Any ideas? Thanks
kinger
Use a hair dryer and get it really hot it will come off. Clean up the residue with goop off.
pat the rat
x2
Goo gone works like magic.
guardrail
WD-40 works good also
bottlerocket
The key is lots of heat but not melting and the glue should come with it.
yamadoo
- Jun 3, 2003
10 Vector LTX Blue 9kmiles
11 Venture GT 4k miles
86 SnoScoot(2) for grand kids
I agree, heat peal then wd 40, I have read that goo gone is very good but that Goof off -sounds similar but does ruin surfaces.
These sound so similar I get nervous which is which and stick with WD 40.
Yamadoo
Yamadoo
Apex2006
- Oct 26, 2009
- McHenry, IL
- Yamaha Sidewinder SRX-LE 2019
Yamaha Sidewinder XTX 141 2017
Yamaha Viper XTX 2015
Yamaha Sno Scoot 2018
Ski-Doo Renegade XRS 850 2020
I use a heat gun but you have to be careful not to overheat. Simply apply heat randomly until you get the sticker started and only apply more heat as required to remove the sticker completely. Goo-gone and Windex for cleanup
