dremmick
- Mar 17, 2011
- Savage, MN
- 2008 Nytro
I want to change my grips to odi or Rsi. Are the stock grips glued in? Can they be successfully removed without disturbing the heating elements?
RobWarrior
- Oct 4, 2008
- Western Ma
- 09 FX NYTRO RTX
I believe they are, I hade RSI and liked them but wore through after 2000 miles. have ODI now they may be the same?
Ethan_Messinger
- Jan 17, 2016
- Wisconsin
- 2011 Yamaha Nytro XTX
I replaced mine, I just sliced them at the ends with a razor blade, and then tore them apart the rest of the way. I just made sure to pull apart instead of up, so that the heating elements don’t come off with it... oh and make sure to drill out the 2 rivets as well.
dremmick
- Mar 17, 2011
- Savage, MN
- 2008 Nytro
I think I might go with ODI. Not sure if I need 7 or 8” grips
dremmick
- Mar 17, 2011
- Savage, MN
- 2008 Nytro
Awesome! The glue must not be that strong then if your can tear the grips off.
TheI replaced mine, I just sliced them at the ends with a razor blade, and then tore them apart the rest of the way. I just made sure to pull apart instead of up, so that the heating elements don’t come off with it... oh and make sure to drill out the 2 rivets as well.
jason22
- Feb 28, 2014
- Newboro Ontario Canada
- Yamaha Nytro
The grips aren’t glued to the bars. Hence the pop rivet.
Only the heating element is glued. And yes. The glue is accually really good . Took me awhile to get all heating element off and rest of glue off bar and when I had to replace a faulty element.
