Ultrafrozen
I'd much appreciate if someone could measure the stock spring size. Mine are 0.406" square, the same as the accessory heavy duty spring listing. Looking to confirm if stock is smaller.
twyztid
- Feb 14, 2011
- Middleville, MI
- 2017 Sidewinder LTX SE - TD Power Trail, CAI, 3" Super Quiet
2012 RS Vector
2006 Apex GT
- Middleville, MI
That's what came stock on my 15 Viper LTX SE that I had. I still have those springs. I had swapped them to the 2016+ springs that are softer right when I got it (it had 46 miles on it). The 2016+ are something like .394" wire diameter.
twyztid
- Feb 14, 2011
- Middleville, MI
2012 RS Vector
2006 Apex GT
- Middleville, MI
If you bend the long leg of those springs that you have to 100° separation from the short leg, you'll have pretty much the same springs as the 2019-2021 Sidewinder SRX. Your stock springs are supposed to be 94-degrees separation between those legs.
Ultrafrozen
Is the 2016 spring round? You say 0.394" diameter which would be softer. If square, it's not much smaller than 0.406". I'll keep investigating, our sledding season likely just ended, went from perfect last weekend to warm and melting for a few days.That's what came stock on my 15 Viper LTX SE that I had. I still have those springs. I had swapped them to the 2016+ springs that are softer right when I got it (it had 46 miles on it). The 2016+ are something like .394" wire diameter.
twyztid
- Feb 14, 2011
- Middleville, MI
2012 RS Vector
2006 Apex GT
- Middleville, MI
Square and .394 across (under the paint)Is the 2016 spring round? You say 0.394" diameter which would be softer. If square, it's not much smaller than 0.406". I'll keep investigating, our sledding season likely just ended, went from perfect last weekend to warm and melting for a few days.
Tomelongname
How was the ride with the softer spring? I am toying with softer spring or rear shock upgrade for same sled.That's what came stock on my 15 Viper LTX SE that I had. I still have those springs. I had swapped them to the 2016+ springs that are softer right when I got it (it had 46 miles on it). The 2016+ are something like .394" wire diameter.
twyztid
- Feb 14, 2011
- Middleville, MI
2012 RS Vector
2006 Apex GT
- Middleville, MI
I never rode it with the stock torsion springs so I don't have anything to compare it to.How was the ride with the softer spring? I am toying with softer spring or rear shock upgrade for same sled.
Tomelongname
Days are getting shorter. Suspension coming out this week and softer spings will be going in, all shocks will be revalved and will comment further when weather permits... Have a great summerI never rode it with the stock torsion springs so I don't have anything to compare it to.
