apexgt4life
I have a 15 and 18 stock vipers. What is the stock settings for secondary twist and or what should i set at.
I feel they were both set different stock?
I think 15 was at 2 and 6
18 was at 1 and something as my mark rubbed off
Now im all confused
Now im all confused
Yamajon1
- Nov 6, 2016
- Oshkosh Wisconsin
- 2016 SR Viper RTX DX
Former Yamaha sleds:
2004 Venture 600 2002 SX Viper 700
1997 Vmax 600 SX 1994 Vmax 600 1989 Exciter
1986 Vmax 540 1986 Phaser 1981 SRX 440
If I remember correctly 70 degrees is stock setting.
apexgt4life
So 1 and 6?
Guees im confused on all the numbers on
Yamajon1
- Nov 6, 2016
- Oshkosh Wisconsin
Yes.
apexgt4life
Ok any other input. One appears to be set at. 6 and 2
Yamajon1
- Nov 6, 2016
- Oshkosh Wisconsin
That would be 1 step tighter, 80 degrees. Lower settings will let the secondary open quicker loading the engine a little more and dropping RPM slightly. Higher settings the secondary opens slower and you may see slightly higher RPM
DennyTuna
- Jan 28, 2017
- Ohio
- 18 Winder LTX 50th
16 SR Viper RTX (red)
02 SX Viper ER (red)
97 SX Vmax 600 (red)
2 -14 Vipers and 2 - 16 Vipers all set at 6-1 from the factory and still today with TPI big Venom kits or Schmidt Bros kit.
Confused
- Oct 12, 2008
- Mound, MN
- '21 Sidewinder LTX SE
'24 MXZ 850 Turbo R Comp
'23 MXZ Blizzard 850 ETEC
'24 MXZ Neo+ 600
'88 SnoScoot
Is there are chart on what settings equal what degree? Or is it specific to manufacturer or model?
- 15K
