LeSerpent
- Sep 13, 2023
- Montreal
- 2023 XTX LE
Has anyone had any problems reinstalling the stub shaft? Mine do not want to go on the block housing. Did i miss something?
Thx in advance.
Thx in advance.
Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
Catefully look the shaft over, There's an Alignment tooth that matches the crank.
It’s a flat spot in the crank that lines up with a flat spot on the stub internals.Catefully look the shaft over, There's an Alignment tooth that matches the crank.
It’s shows at the beginning of this video.
LeSerpent
- Sep 13, 2023
- Montreal
- 2023 XTX LE
Yes i see. But i cannot put the stub shaft freely on the block. Normal?
It can be a pain if it’s not perfectly aligned. Why did you pull it apart?Yes i see. But i cannot put the stub shaft freely on the block. Normal?
You can hold the flange part you bolt on and slightly turn shaft one way or the other and it will go on.
LeSerpent
- Sep 13, 2023
- Montreal
- 2023 XTX LE
I change the bearing and loctite it.
I've mark with a sharpie the location of the shaft on the block.
The stub shaft was hard to get out.
I try to reinstall the stub shaft with no succes.
It look very tight to getter in place....
I need advice.
I need advice.
LeSerpent
- Sep 13, 2023
- Montreal
- 2023 XTX LE
Ok thx. I will try that way.It can be a pain if it’s not perfectly aligned. Why did you pull it apart?
rev them up
- Apr 3, 2006
- Prince Edward Island, Canada
- 2011 Nytro XTX, Hurricane Exhaust, K&N, Pcv, Autotune, Pod300, Star Suspension,
2018 Sidewinder, TD Max Spool 17, CAI, TD 3 Inch Stock Muffler Mod, 3Bar, BOV
Is there any burrs on either spline?
LeSerpent
- Sep 13, 2023
- Montreal
- 2023 XTX LE
No.Is there any burrs on either spline?
Do you need to tap on the housing to put in the bloc?
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
Heat the block up lightly, it's a tight fit.
Turboflash
- Mar 18, 2019
- Southern MN
It helps to slightly chamber the block edge and the corner of that step on the stub. Freeze the stub for an hour, warm up the block with heat gun. It'll go right in by hand.Yes i see. But i cannot put the stub shaft freely on the block. Normal?
