21GT
Hello, yesterday I removed my Stub shaft assembly to press my bearing back in as it moved in the housing. The assembly came out pretty hard once I got it out I noticed the lip on the case seal was damaged from the removal. Anyway to avoid this? And does anyone have a extra seal they'd be willing to sell? I've called all over and they are on backorder unfortunately.
Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
Unless someone else chimes in, Goggle "barn of parts" he should have it.
21GT
Thanks for the response. I gave him a call he might have a used one and is going to check. Don't really wanna put a used one in but I might not have a choiceUnless someone else chimes in, Goggle "barn of parts" he should have it.
Doc Harley
- Oct 17, 2016
- Here & there
I reused mine three or four times. It probably would help you if you'd use a heat gun to heat the block up around the housing, before you pull the housing out. I just tried it a week ago and it just slipped right out.Thanks for the response. I gave him a call he might have a used one and is going to check. Don't really wanna put a used one in but I might not have a choice
sideshowBob
I have a couple but by the time I get it to you from NWO Canada winter will be over.
Turboflash
- Mar 18, 2019
- Southern MN
Partzilla says they're back in stock on Jan. 18 or 19. I checked the Cat part 3020-217.Hello, yesterday I removed my Stub shaft assembly to press my bearing back in as it moved in the housing. The assembly came out pretty hard once I got it out I noticed the lip on the case seal was damaged from the removal. Anyway to avoid this? And does anyone have a extra seal they'd be willing to sell? I've called all over and they are on backorder unfortunately.
21GT
Thank you I have one on order from them. Wel see what happens.Partzilla says they're back in stock on Jan. 18 or 19. I checked the Cat part 3020-217.
Doc Harley
- Oct 17, 2016
- Here & there
I put myself on the list with Cat country....see how that goes.
Ty, turboflash
Ty, turboflash
Paystar
Hmmm, I went yesterday and my dealer has the seal on order and will be here by next week. Wasn’t showing backorder.The bearing on the other hand is back order until May!!
Doc Harley
- Oct 17, 2016
- Here & there
What state are you in? Cuz we are both about to laugh really hard. LolHmmm, I went yesterday and my dealer has the seal on order and will be here by next week. Wasn’t showing backorder.The bearing on the other hand is back order until May!!
Strike that.... My dealer told me there was one left in the country and I grabbed it. But I think you beat me to it. Hahahaha.....nice job!
Hopefully the system works on allocation, and there was one left after you placed your order.
Paystar
Maine. We called around yesterday for a bearing and a dealer had just gotten the bearing yesterday about an hour south so I put my name on it.What state are you in? Cuz we are both about to laugh really hard. Lol
Doc Harley
- Oct 17, 2016
- Here & there
The seal I found was in Wisconsin. So maybe I'll still get it. I just thought it was funny that you and I were grabbing for the same seal.Maine. We called around yesterday for a bearing and a dealer had just gotten the bearing yesterday about an hour south so I put my name on it.
Paystar
Would be funny, mine is through cat. Maybe you’ll get lucky.The seal I found was in Wisconsin. So maybe I'll still get it. I just thought it was funny that you and I were grabbing for the same seal.
Doc Harley
- Oct 17, 2016
- Here & there
Yeah, maybe... Haha ill let you know.Would be funny, mine is through cat. Maybe you’ll get lucky.
Turboflash
- Mar 18, 2019
- Southern MN
PTO snub shaft bearing is 6307-2RS C3. Should be able to source anywhere but get a good one (NOT China). NSK, NTN, SKF, FAG, KOYO, Timken, etc.Hmmm, I went yesterday and my dealer has the seal on order and will be here by next week. Wasn’t showing backorder.The bearing on the other hand is back order until May!!
For example: https://www.amazon.com/6307-2RS-rubber-bearing-6307-rs-bearings/dp/B00PCNW5NA
