09phazermichagan
so i drilled 96 holes into my track today V pattern useing a studboy narrow track template well the thing is the widest part ot the pattern/furthest out stud backers are right on the edge of the window not hanging over the window but really close is this ok? i could change it so those sections of the pattern have two studs in the middle insted of all the way on the out side but could i leave the holes i drilled that i dont need empty or will it cause the track to come apart by these holes? anys advice would be great thank you
