Rtbo
- Feb 18, 2016
- N Syracuse
- 23 SRX
- N Syracuse
I’m looking for a stud pattern for a 137” track using 48 doubles and 48 singles using the cb template. I’m going to do all center to start and if needed I’ll do 48 more on the outside. Would like to know the numbers or letters for each bar. Thanks
snowdust
- Oct 26, 2003
- Northern Illinois
- Sidewinder
https://docs.google.com/spreadsheets/d/16yaV2FFr5oNKfAkcBoHY7qYsTXsQP7E_kZz3Nkk_t_k/edit?usp=sharing
Something like this might be what you are looking for.
Rtbo
- Feb 18, 2016
- N Syracuse
- 23 SRX
- N Syracuse
Thank you that does help. Are you running that pattern? Any vibration? Wish you did anything different?
Rtbo
- Feb 18, 2016
- N Syracuse
- 23 SRX
- N Syracuse
I’m putting in a 1.5 storm with 1.625 top gun2 with the air lite xl backers and tall nuts. Think you could sneak one more column to the center or are the center louvres a concern?
blevis213
- Apr 13, 2013
- hadley, new york
- 2014 apex se
2001 srx 700
2000 srx 700
2021 sidewinder srx
I was messing with the pattern today. I left all the doubles where they were. Instead of starting with 3 I started with 9 then 7 then 3 then 2 on the singles. Repeat as u move down. That way gives another v pattern. Another way is go 9,7,3,2 then go backwards 3,7,9, then 7,3,2 and so on. That will give u a diamond pattern with singles and v pattern with doubles. Any one see either way being a problem.
This is inside only
This is inside only
snowdust
- Oct 26, 2003
- Northern Illinois
- Sidewinder
I am not running that pattern so can't say for sure, but it is balanced so I can't imagine a vibration. The center was open to clear the center protector in the rear. When you lay it on the track you'll see it's actually not that much open in the center. The google sheet is misleading vs. reality.
Rtbo
- Feb 18, 2016
- N Syracuse
- 23 SRX
- N Syracuse
Thanks for the help guys.
blevis213
- Apr 13, 2013
- hadley, new york
- 2014 apex se
2001 srx 700
2000 srx 700
2021 sidewinder srx
Give me some more time on this before anyone tries itI was messing with the pattern today. I left all the doubles where they were. Instead of starting with 3 I started with 9 then 7 then 3 then 2 on the singles. Repeat as u move down. That way gives another v pattern. Another way is go 9,7,3,2 then go backwards 3,7,9, then 7,3,2 and so on. That will give u a diamond pattern with singles and v pattern with doubles. Any one see either way being a problem.
This is inside only
Rtbo
- Feb 18, 2016
- N Syracuse
- 23 SRX
- N Syracuse
Does anyone see anything wrong with this pattern? Trying to get maximum scratch lines. That’s 20 scratch lines repeated 4 times
- 24K
