Stud Pull Through Repair
dylanjen9
Florence WI
Is there anything that can fix a track were studs have pulled through? If so has anyone tried it and how has it worked?
repair
depends on where the pullout is, but generally, no, its not feasible to fix it. if its not near the edge of the track, or torn into on of the windows, dont worry about it. just trim it out so its no longer a "flapper".
Not sure what happened to Caroll Tech. I used them a long time ago and the repair was amazing. Just tried to find them and web said no server. Believe they were somewhere in WNY? Hope they aren't gone.
dmax66 said:
cental ontario track repair uses the carrolltech process.
Where about's in Central Ontario, do they have a link/website (can't look at work fsr?)
If you have allot of miles on the track, their is a good chance the track could be starting to come apart internally. If you find yourself tightening the track allot after broken in and/or premature stud pull throughs, thats a good sign its time to replace track. Your not going to get a blatant flat tire telling you its time to replace so its good to be proactive before you spend on short term repairs.
Dan
Track Repair
A good friend of mine on this site, NY AttakGT had his track repaired with great success from a company in Albany, NY. Send Steve an email if you want the contact information. They claim they can shorten the track and it will be as good as new.
