Studding an XTX
Just my opinion, I don't think 144 is a lot of studs. Everybody in our group has the same amount and we don't have any problems throwing the rear end around and having fun in corners. I don't think 144 would limit you in anything you wanted to do.
I agree with 100% but..... I only want to run doubles, that means 114 or 228 and 228 is way to many..... if I boost this thing next year maybe 228 but for now I will stick with 114.
P.S. I have a XTX so 144 studs is for a 121in track mine would require 171 studs in the same pattern you speek of.
That is the pattern I an running in my XTX. 171 I am also running a holtzman 40 shot of go go juice.
I am running a 1.25x 144 preditor, and am using a 4-2 patter. You can double the 4's up. Problem is the odd number lugs you end up with 2 4's together. You could also go 3 every row, and double 2 of them on one side of center, and single the other. Maxdlx
Ok, here is what I have come up with.......attn: guys wanting to ONLY run double backers on thier XTX. This is a Firecat/Sabercat woody's stud template for 128/144 inch tracks that at first I tried to cut it in the center and widen it........but..... the windows on the XTX are HUGE, thus making the studs to close fore comfort to the windows ( about a 1/4 inch). So having a Firecat,a Nytro RTX with a 1.25x16x136 doo track on it, and my XTX all in the shop I did some comparing to make sure this would work. Its simple, I added some thin cardboard to the one end of the template with superglue and widened the track openings by 5/8 of an inch on each end.........thats it. I put it on the track and it seems to be perfect.
Pics coming......having problems loading.........
:-o
Pics.....
lucky_7 said:
Is 108 enough? I always use '1 stud per horsepower' theory...which would be in the range of 135-138 :Rockon: !!...which would put you in the 144 range.
Anybody that puts 108 studs in a 135+ HP sled is asking for trouble. It puts too much stress on the studs. You are asking for trouble with pull throughs or bending. This is like putting 96 studs on a 121" track, in a 800 two stroke. You have to go at least 144 (121" track) or so on a sled with this kind of power. At the very least, 120. JMO.
I had 153 picks with tall nuts in my F7 and I have a track that looks like swiss cheese after 5000 miles............sorry I don't buy that....double backers make a world of difference. 114 on a 144 for me. and I bet I dont loose a single stud! :tg:
Sorry Buddy, 108 studs on my Firecat F7 (140hp) rode 5,500 miles I'm 250lbs and NEVER tore out a stud, bent 3 total....., I trust me I ride HARD!!!!
I'm going with 114 on the XTX, mostly cause too many studs add weight and KILL your top end!!!
I ran 114 on double backers with 3/4" tall nuts on my 144" Gade for more than 12,000 miles without a bent stud, no pull throughs and at least 160hp without using the Nitrous. It all depends on how you ride, whether you are a drag racer or spin the crap out of your track coming out of corners.
I just finished studding my XTX last weekend. Used only doubles in this pattern
XX XX
XX XX
EMPTY
XX XX
XX XX
EMPTY
XX XX
XX XX
XX XX
XX XX
EMPTY
XX XX
XX XX
EMPTY
XX XX
XX XX
XX XX
XX XX
EMPTY
Repeating this pattern around track gives you 172.
It shouldnt be. The pattern you see is 1/3 of the total track, as a whole it should be balanced...............I guess Ill know in a few weeks.
Post some pics of the finished product, I am going to be studin mine tonight, its been drilled, I'm just waitin for my buddie to show up with our custom machined TALL NUTS, I will post a few pics later tonight.
:jump:
