fourbarrel
Building a collection one sled at a time
What a PIA to stud this track!!! I think they call it a silent track,with those ramps on the inside for idler wheels to ride on for noise suppression.Yeah well those ramps are not the friendliest thing to have to work with.My track drill didn't cut through them when I drilled the holes so now I'm fighting with the studs to push them through.My hands are aching and sore from all the awkward angles of trying to force the stud through these damn rubber ramps. Does anyone have a secret to studding this type of track? I still have about half to do yet and any tips would be greatly appreciated.
blevis213
- Apr 13, 2013
- hadley, new york
- 2014 apex se
2001 srx 700
2000 srx 700
2021 sidewinder srx
I just used woodys track cutter tool had no problem going through my1 inch track. Woodys track template with triggers no issue putting them in.
fourbarrel
I've got the Woodys template too but my studs are from a local guy that sells SnowStuds products,used to be Saber.I don't know what I did wrong but the cutter just didn't take all the material out from these rubber ramps.I have never had an issue like this before with the other sleds I have studded before,but then again those tracks were not this style either.
blevis213
- Apr 13, 2013
- hadley, new york
- 2014 apex se
2001 srx 700
2000 srx 700
2021 sidewinder srx
Not sure I did 3 this pass season with no issues. Is the track cutter beat? Is it the right size diameter as the studs? Just trying to help eliminate things.
fourbarrel
Brand new 5/16 cutter bought from the same guy I got the studs from.I have an idea that I might try tomorrow night when I finish this project.I'll take a small piece of wood and hold it against the inside of the track and redrill the hole to see if it cuts completely.
snowdust
Seems odd you are having trouble but I use something similar to this: https://www.amazon.com/Urrea-Air-Dr...26029&sprefix=22,000+air+drill,aps,124&sr=8-1
Makes quick work of the job and gets hot quick to cut a nice hole.
Simplespeed
- Jan 8, 2022
- 1191 Sauk Lane , Saginaw, Mi. 48638
- 2006 Apex , 2017 Sidewinder LTX -LE
Short T handle allen inserted into stud and use that to push studs though the hole.. you want smaller hole to keep stud flex at minimum which in turn helps the stud to stay straighter and less load on the plate…. Easier for studs to pull though if hole is bigger/ sloppy right ??? Snowdust is right the cleaner the cut the better and heat helps make a good clean cut as the cutter gets hot all the better ….
STAIN
- Feb 29, 2004
- Vermont
- 2022 SIDEWINDER LTX GT
- Vermont
get a new cutter. or make one. should be no problem.
Turboflash
- Mar 18, 2019
- Southern MN
Try sharpening cutter? Use a little lubricant right where hole is going.Brand new 5/16 cutter bought from the same guy I got the studs from.I have an idea that I might try tomorrow night when I finish this project.I'll take a small piece of wood and hold it against the inside of the track and redrill the hole to see if it cuts completely.
snowdust
If you use that 22k rpm tool you do want to be quick in and out once it gets hot so the hole is nice and tight.. leave it in there too long and the holes to get a bit bigger than you would want.Short T handle allen inserted into stud and use that to push studs though the hole.. you want smaller hole to keep stud flex at minimum which in turn helps the stud to stay straighter and less load on the plate…. Easier for studs to pull though if hole is bigger/ sloppy right ??? Snowdust is right the cleaner the cut the better and heat helps make a good clean cut as the cutter gets hot all the better ….
DooZ
Heat the cutter with a torch and re-cut the existing holes, do the same with the additional holes. It'll stink like a b!tch, but you'll get good holes
- 147K
- 47K
