sk-rx1
After many years away from Yamaha I purchased a 2017 SW XTX LE with the 1.75 track. I want add add some studs, mostly to make it easier to load into the trailer on icy parking lots. I see some have used the igrip studs. I see some recommend the 28mm ,some say 32. Also, I am not familiar with the SW as to heat exchanger protection. Do I need to add full length protection? I see a rear protector that many are using. Also, is there a preferred stud pattern or is it not that important with the small igrips? I know many of these questions are covered in a few places but I have not been able to find all the answers. Thanks in advance for any help.
That’s would be a lot of stud in that track. I’d do I grips or something. Full length protectors depends on length of stud past lug.
sk-rx1
Yes, was planning igrips. Do I need the small protectors? Is there any specific pattern?
I would put on the tears. No need on the tunnel. Make sure you don’t put them under tunnel cooler. I’d do at least 4 per row.Yes, was planning igrips. Do I need the small protectors? Is there any specific pattern?
sk-rx1
Thanks, sounds like a plan. Did you use the 28mm or the 32. Igrip recommends 32 but I saw somwwhee that some are using the 28 to allow the lugs to felx.
I have done them with both. I like the longer version.
Snowbound98
- Mar 11, 2019
- Chicagoland
- 2015 SR Viper M-TX 153
Little late to the game here but for any future inquiries.
sk-rx1
Thanks, that helps a bit.
IceStriker
- Jan 27, 2014
- Nashotah, WI
- 2007 Yamaha Attak GT
Curious as to what you ended up doing? I'm looking to do the same thing with my Backcountry on my Viper. Do you need to install a protector, where? What size screw did you go with? Thanks!Thanks, sounds like a plan. Did you use the 28mm or the 32. Igrip recommends 32 but I saw somwwhee that some are using the 28 to allow the lugs to felx.
sk-rx1
I have not done anyting yet, may ride it a couple times then decide. I will likely get the tunmel protector kit, not sure on the 28 or 32. Cant be much help....
Fast Lane
- Feb 6, 2020
- Winnipeg
- 2007 Yamaha Nytro ER
- Winnipeg
I'm also interested in these igrip screws. They interest me!
Snowbound98
- Mar 11, 2019
- Chicagoland
I put the 32’s in my 18 XTX SE 137 that has the 1.75 backcountry track. The pics above are the IGrips I used and also the pattern. Pre drill and use some dish soap on the threads. Made a huge difference in traction. I’m not a fan of using studs on a single ply track.
Go on IGrips website and it tells you which stud to use. I can’t remember where I found that pattern. It was on some random site that I happened to stumble across searching. Had a few different tracks as well. If I can find it I’ll post a link.
northwindwinder
- Apr 12, 2023
- St. Germain
- sidewinder gt
I put 256 in a 1.75 Hurricane track. Some 32s, some 28s. Some of the track paddle locations dictate which. Thing hooks great in general trail riding conditions. I dont go to the local ice drags anymore, so dont need the "Cat on a screen door" type of traction anymore.
Snowbound98
- Mar 11, 2019
- Chicagoland
These IGrips have been in for 2 years and none have come loose and still look great.
mbinhali
- Jan 6, 2026
- Minden
- 2016 Yamaha Apex x-tx 1.75
I'd like to install the iGrips screw studs in my 2016 Apex X-TX 1.75 (Backcountry track). Does anyone know if there is adequate clearance to do so and if the sled comes with tunnel & exchanger protection on it? Sled is stock. I am planning on the st-24r studs which will extend 5mm or 3/16 beyond the paddles.I have done them with both. I like the longer version.
