Andrew
- Nov 30, 2012
Hey I have a 2010 vector ltx gt. I am wondering if I can put studs in the rip saw track that's on her now. And if so what size will I have to get without doing any mods
ApexSE/Vector
- Dec 12, 2010
I had Studboy's 1.375's in my 08 Apex ltx (same track and chassis I believe as yours) and over time they chewed into the rear muffler bracket/support almost cutting it in half. This bracket is a lot larger than what you see underneath (goes up both sides and is close to $400 (Cdn) to replace. I ended up riveting a piece of 1/8' aluminum plate to what was left. I would run nothing longer than Woody's 1.325's and would even consider the even shorter Studboy 1.280's in a 3-2-3-2 patter for a total of 135 studs
Andrew
- Nov 30, 2012
Shitty deal. Does it matter if my track just about three years old? (Original)
Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
Andrew said:Hey I have a 2010 vector ltx gt. I am wondering if I can put studs in the rip saw track that's on her now. And if so what size will I have to get without doing any mods
Right above you, in the sticky's
http://www.ty4stroke.com/viewtopic.php?t=88497
ApexSE/Vector
- Dec 12, 2010
No it shouln't as long as you keep an eye on you track tension.Andrew said:Shitty deal. Does it matter if my track just about three years old? (Original)
Gone Blue
- Oct 11, 2006
- Howell, Michigan
Does your 2010 LTX have the rear cooler? If so, you will need to rivet on chunks of old hyfax on the cooler protectors to prevent the studs from chewing up the cooling fins. The protectors are not tall enough if you run studs. Been there done that on my 07' Rage GT. G.B.
Andrew
- Nov 30, 2012
What size thread would be best for that type of track?
IAVECTORGT
- Oct 19, 2011
- Iowa City, Iowa
- 2015 Arctic Cat ZR 8000 El Tigre
X2! Right on Irv!Irv said:Andrew said:Hey I have a 2010 vector ltx gt. I am wondering if I can put studs in the rip saw track that's on her now. And if so what size will I have to get without doing any mods
Right above you, in the sticky's![]()
CaptCaper
- Jan 1, 2007
- Northern N.H.
Did ours with 1 1/2 in of protection over the cooler with 1.325 recommended by Woody's. Same with my Attak. They have held up well. But you'll need to fabricate protection over the cooler.
