03RX1-ER-LE
Bleed BLUE
- Feb 22, 2008
- 2011 Apex XTX 12,497 miles
2009 Apex ER 8,169 miles
Tow Vehicle
2021 Wolverine X4
- Livonia Michigan
I have been using WD-40 for 40 years on my sleds without a problem. I spray everything but the hood/tank/exterior of the tunnel. I even spray clutches and then wash them in the fall and go over them with a scothbrite pad when dry to clean them. Here is a underhood shot of my wifes old Venture after 9 years, I dont have any RX underhood shots currently and sleds up north, as you can see it still looks like new.stomper said:Cubby said:I have quite the detailed summerize to do list. I store it in the shed over the summer:
Stabilize gas
Oil change
Chain case oil change
Fog engine
Plug exhaust
Wash and clean sled
Repack speedo bearing
Repack secondary clutch bearing
Polish aluminum and plastic
Touch up paint on frame
Remove battery, charge it and store in the basement for the summer
Grease all the zerks in the skid
Remove belt for the summer
Clean and dry belt
Clean airbox foam
Clean clutches (compressed air and simply green)
Grease front shocks bushings
Grease rear shocks bushings
Grease ski spindles/collars
Store with front and rear suspension off the ground
Remove seat and store in basement
Cuddy, for the clutches do you just spray the simply green on them and blow them out or do you soak them in it and rinse them off after.
When you guys are spraying your sleds down with fluid film, wd 40 and other similar stuff are you spraying the engine and everything else under the hood?
Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
03RX1-ER-LE said:I have been using WD-40 for 40 years on my sleds without a problem. I spray everything but the hood/tank/exterior of the tunnel. I even spray clutches and then wash them in the fall and go over them with a scothbrite pad when dry to clean them. Here is a underhood shot of my wifes old Venture after 9 years, I dont have any RX underhood shots currently and sleds up north, as you can see it still looks like new.stomper said:Cubby said:I have quite the detailed summerize to do list. I store it in the shed over the summer:
Stabilize gas
Oil change
Fog engine
Plug exhaust
Wash and clean sled
Clean and dry belt
Clean airbox foam
Are your sleds stored indoors or outdoors during the off season? From my experience, the WD-40 didn't last long at all on anything that was stored outdoors.
tomanytoyz
I start my machine 2-3 times a month since the very first day i brought it home 8yrs ago ! and this is one reason why my sled runs soooo dang good!
Its never just sits around for many months to be ridden again..
Some may say this is bad to do,but i disagree. everything i own is >>Exercised<<though out the year and is ready in a min! from weed whips -mowers-generators-toyz-etc-etc
To each there own and good luck to your summer storage
TRiGGeR605
I'm with you tomanytoyz, I would think having your machine sit for 7-8 months would be hard on it. Doesn't running them every now and then keep the gaskets from drying out? I run mine up to operating temp once a month.
tomanytoyz
Yes this is also true keeping seals in great shape this way.TRiGGeR605 said:I start my machine 2-3 times a month since the very first day i brought it home 8yrs ago ! and this is one reason why my sled runs soooo dang good!
Up to temp is very short in the warm .
Battery is fresh ,injectors pumping,etc -->>> all systems go
newfie09xtx
- Jul 13, 2011
- Corner Brook, NL
- 2016 Polaris Switchback 800 Pro S
tomanytoyz said:Yes this is also true keeping seals in great shape this way.TRiGGeR605 said:I start my machine 2-3 times a month since the very first day i brought it home 8yrs ago ! and this is one reason why my sled runs soooo dang good!
I did this last year and fouled new CR10EK plugs. I always let it warm up till the light went off and a little longer.
Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
Asked this same question a few years ago.
Fog for me, as I have normally done with my previous 2 strokes.
http://www.bobistheoilguy.com/forums/ub ... er=2623847
