craigjschr
i am putting the sleds away and i was wondering if any one has a service manual for a 2006 apex. alos i was going to change the oil gresse all the fittings amd greece the jack shaft bearing and fill the tank and put stabol in it. is thier anything elese i should do.
thanks
thanks
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
Here's the link for the manual http://www.filesend.net/download.php?f= ... 03aa72011a. I would check the front bushings on the a-arms and then check your drive axle for cracks and your exhaust donuts. O give it a good bath.
craigjschr
should i change the plugs and if so what ones should i use.
APEX 06
- Apr 30, 2009
- Sheboygan, WI
I would it takes a little time but its good to do and us the stock pulgs from yamaha.
- 6K
