ROCKRTX
I got a problem with the bushing in the weight,it is always sliding on one side with centrifuge force of the clutch and hardly move on the pin when append.I have to remove the weight,tap the bushing and reassemble.
How can i prevent the bushing from sliding?
Len Todd
Did you install the shims on each side of the bushing? There should not be much room left, with these installed.
You might want to consider replacing the bushing. They fit very tightly. If it is moving, it needs to be replaced.
sledhead_dan
Same problem , weights have less than 400 miles on them. Proper plastic shims are installed but bushing still binds up the weights movement. What about removing bushings , applying loctit and reassemble ???
ROCKRTX
sledhead_dan said:Same problem , weights have less than 400 miles on them. Proper plastic shims are installed but bushing still binds up the weights movement. What about removing bushings , applying loctit and reassemble ???
I was tinking the same, put green loctite but don't know if it work.
ROCKRTX
I pull off the bushing and put some green loctite and it work. Just to, let you know.
sledhead_dan
Thanks for your info, I will try the same
snowy1
locktite worked for me.
