KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
Mine was cutting out when I do standing starts , with anything under 1/3 of a tank . The two pick ups , one was not laying in bottom of tank , had to reposition it . # 30 on diagram. If you hammered through a really rough trail they must bounce around.
Thats very possible! I'd be checking that eightpilot.
eightpilot
- Mar 17, 2009
- Mosinee WI
- 2021 Thundercat
- Mosinee WI
I will for sure when I get home. Weird tho,, because if the surge tank is working properly then it shouldn’t matter... wouldn’t you think??
KnappAttack
- Feb 19, 2004
- Welch MN
Can't keep up sucking air! You are going to need to get a look in there I think. Shouldn't be running out of fuel.
eightpilot
- Mar 17, 2009
- Mosinee WI
- 2021 Thundercat
- Mosinee WI
Yeah.... I’m gonna tear into it when I get home.
Mototown
- Sep 11, 2018
- Apex 40 th
Did you find anything?
eightpilot
- Mar 17, 2009
- Mosinee WI
- 2021 Thundercat
- Mosinee WI
Not yet. Just got home....
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
The Precision EFI fuel upgrade kit eliminates this problem as it returns the fuel right back into the fuel pump area rather than the front of the tank, this keeps that "banana clip" full at all times.
eightpilot
- Mar 17, 2009
- Mosinee WI
- 2021 Thundercat
- Mosinee WI
Well I pulled it out and everything looks fine. Pickups are on the bottom of the tank like they should be... Only thing i saw was the fuel pump housings gasket had a slice in it. So i swapped the entire system out with one i had from a wrecked winder i bought. Will test next week sometime if we ever get cold weather back....
sledding rocks
- Feb 11, 2017
- north
- sidewinder
was this a stock fuel pump or after market that is giving u issues ?Well I pulled it out and everything looks fine. Pickups are on the bottom of the tank like they should be... Only thing i saw was the fuel pump housings gasket had a slice in it. So i swapped the entire system out with one i had from a wrecked winder i bought. Will test next week sometime if we ever get cold weather back....
eightpilot
- Mar 17, 2009
- Mosinee WI
- 2021 Thundercat
- Mosinee WI
Stock
