A
Anonymous
I forgot to say
I forgot to mention I am working on dipsticks for the phazer too. Keep the coments and any sugestions coming.
fx10mtx
Would also be interested
Yup, interested.
A
Anonymous
Keep it up it is showing there is a need for this!
Nytro Fx
yup i would get one
SpecRTX
- Mar 11, 2006
- Speculator, NY
- 2018 Thundercat
I think this is a great idea...something that should have come from the factory.
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
Yamaha had magnetic Chain Case dip sticks in the past, there were usually some steel shavings on the magnet on every oil change.
A
Anonymous
the reason i made this is because i had a sled with one and it was shocking what i would pull out of the chainecase, lookes like pencil shavings and i knew that would shorten the life of the chainecase. you may spend a few bucks but it could save you lots of money down the road. There is a reason every other snowmobile company has one stock on there sleds. and the slip on will be cheep I am guessing around 15-18 dollars i don't know exactly yet.
A
Anonymous
comming soon!!!!!!!!!
cawcislo
Way to step up and create a solution for everyone from the budget minded to those who want that custom look. Looking forward to the prototype.
A
Anonymous
thanks
thanks i appreciate what you are saying and i am happy to hear that somone thinks like me
cawcislo said:Way to step up and create a solution for everyone from the budget minded to those who want that custom look. Looking forward to the prototype.
IFlyEm
How much?
mach9
I often thought that magnets were better located imbedded into the drain plug bolt.
12mm yes??
I wonder which one fits.
http://www.magneticdrainplugs.com/metric.htm
12mm yes??
SledFreak
- Feb 7, 2005
- Ontario. Canada
sj said:any magnet that is placed into the chaincase comes with risk and a degree of liability..if the magnet ever becomes unattached , major damage is possible..
I added 3 rare earth magnets to the outside of the chaincase portion of the dipstick on my attak and worked pretty well..
Ski-doo has been running this for ever. I don't see an issue.
A
Anonymous
SledFreak said:sj said:any magnet that is placed into the chaincase comes with risk and a degree of liability..if the magnet ever becomes unattached , major damage is possible..
Thats were I got the idea from when I had a rev. It was crazy what I pulled out. dont know price yet. still testing to make sure the glue I use is the right one and won't fail. This is also a way to make sure there is no major problems, if there is to many or to big af shavings than normal you know there is a issue. You cant do that if the drain bolt is magnetick unless you drain the chaincase. My idea you can check to see if there is any issues anywhere, on the trail, in the garage, at the gas station, anywhere anytime!
A
A
- 9K
