SRXracer
found a service manual online for the xf 7000, the viper twin, and it has a very good section on suspension setup for handling. Some of it is a little counter intuitive, so I would highly reccomend a read thru it. It starts on page 168. One thing it mentioned was to cure darting, actually decrease center shock pressure to put more track on the snow under deceleration... interesting.
It also mentioned how the rear skid setup is very sensitive to adjustments and will effect top speed - "slows down by 5-8 mph".
Here's the link: http://countrycat.com/ccstore/kbase/snow/2014/ZR_XF_M_4-Stroke.pdf
from page 169:
Having very light front arm spring tension is desirable. When riding in 4 in. or more of snow, the machine will be quicker if the front spring tension is adjusted lightly.
If the spring tension is adjusted too stiff, the track angle at the front of the skid frame is steep. This steep angle prevents the snowmobile from getting up on plane and slows down by 5 to 8 mph. Also, the following could occur.
1. Slows machine down in loose snow.
2. Causes the snowmobile to dart and dive as a result of less track on the ground on deceleration.
from page 169:
