frees-tyler
One side of the bracket has a round peice of metal welded to it, this is so the cables won't suffer chaffing or cutting.
True Blue
sniperviper
You need handguards with that fx windscreen.
teerex
sniperviper said:You need handguards with that fx windscreen.
Do you have studs in your ice machine ?
sniperviper
No studs. "ice machine" because of the snow that is melting from exhaust and water spreading inside and outside of tunnel and then freeze to ice....
Going to buy that new freeride track from camoplast. A friend of my have studdes his sled but I really dont like it...
Clutch are slipping under accelration so I think he have to change the setup to get it work right.
Racer269
Just buy some 8mm plastic bolts..no need to re-locate the tach. If you flip..the bolts will break.
Racer269 said:Just buy some 8mm plastic bolts..no need to re-locate the tach. If you flip..the bolts will break.
The sled looks soo much better with the tach below the bars and not sticking 5" above. Thats was reason enough to move mine.
True Blue
sniperviper
Got the Acerbis hand guards if you can see them in the
top picture.
TB
top picture.
TB
