Sidewinder
- Mar 19, 2005
- Ontario Canada
- www.streettechracing.com
- 2017 Yamaha Sidewinder LTX LE
- Waterloo
Me and my g/f and a bud of mine all run the nylon backers, havent lost 1 yet in 3 years of riding on any sled.
Our 2 run about 1000 miles a year , my bud well over 2k a season, he lives on the trail so he rides to work, the store whatever he wants to.
Scott
Scott
richierich
- Apr 23, 2003
- Greenville,WI
- 08 Apex LTX
The two sizes of tall nuts are 1/2" and 3/4".
1/2" for 1.325"-1.40" studs
3/4" for 1.45" and bigger.
if you use to tall of a nut on the shorter studs you wont get any penatration because it will be to far up on the stud shank.
some info
standard stud nut=3 grams
3/4" tall nut=4 grams
1/2" sold out so dont know but i would say 3 grams
mack nut=4 grams
mack support washer=4 grams
if i were to go with a setup it would be just the taller nuts.they are cheaper and lighter then other options.
some info
mack nut=4 grams
QCRider
- Feb 27, 2004
- Seacoast Region, New Hampshire
- www.myspace.com
richierich said:The two sizes of tall nuts are 1/2" and 3/4".
some info
mack nut=4 grams
If weight is your number 1 concern, don't buy the Macks. If you are looking for quality and long life the Macks kick #*$&@.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
In have used the fastrac polymer backers for many years..and they are incredible...never had any issues to date....i wouldnt recommend NYLON backers though,seen them come apart before..
only plastic backers i would ever use would be fast trac polymer,which i ONLY use...never would i use alum or steel..alum bend too much and steel wayy too heavy...i would however recommend the XL thicker polymers with a longer stud like the 1.325s or more....Im using the Xls and the short barrel tall nuts,which still leaves me just enough for good penetration.
dan
dan
RTX
- Mar 31, 2005
- massachusetts / maine
- 2014 viper rtx
2006 apex rtx
i used the mack spacers too.
i looked into prices before i bought and you can get the mack spacers for at least half of the cost of the woodies nuts. yes they do weigh a little bit more but over all on 144 studs you are only talking about ounces. not too big of a deal to me
first time using mack studs and spacers. curious to see how they hold up.
Blue Me
Thank you!!!!machzed said:In have used the fastrac polymer backers for many years..and they are incredible...never had any issues to date....i wouldnt recommend NYLON backers though,seen them come apart before..
dan
