Crossfire12
- Feb 13, 2017
- New York Adirondacks
- Sacandaga reservoir
Sounds like a lot of clutch changing with that bundle, no?
Dial the clutches for the tune you use the most
WVTurboLTX
- Nov 9, 2014
- 2009 Nytro XTX
2017 Sidewinder LTX LE
With the SM tunes I calibrated for max 16 at 9k. Power trail runs at 8800 or so with same clutching. I've never even set it on ecotrail.Sounds like a lot of clutch changing with that bundle, no?
The big reason I wanted the flasher was upgrades down the road along with riding different areas. Some areas don't care how quiet the sled is, if you change the muffler you can get a ticket (Quebec). I'll use the SM tunes there. Other areas I'll run the superquiet and crank it up(Michigan, New York). Does not take long to swap a muffler and adjust weights when getting ready for a week long trip.
Turbo Dynamics
- Jun 16, 2016
- Gatineau
- 2017 Yamaha Sidewinder
2014 ZR9000 turbo
- Gatineau, Quebec, Canada
- turbodynamicscanada
- YOUTUBE
- TurboDynamicscanada
Whos muffler mod do you run?I am also interested in max spool 16 for stock muffler sound. I've run muffler mod, the drone noise drives me nuts on trail, the excell pipe even though a tad louder is much better sounding.
am I wrong or is the only "quick spool" tune TD offers Max Spool 16 which is designed for stock muffler? I'm a TD client, super quiet muffler, cold air, flasher, running "Maxpump". Really wanting to add a maxspool tune to my bag of tricks without jumping ship.
Turbo Dynamics
- Jun 16, 2016
- Gatineau
2014 ZR9000 turbo
- YOUTUBE
Max spool 17 and max spool 19 and 20 is available but only if you have a 3 bar map sensor.
You may be running regular Max 17
Perfect! Looks like it’s time for a 3bar
Thanks Ben
Thanks Ben
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
The TD max spool tunes work very well.
I was thinking of getting the max 16 with TD muffler mod along with cai. Was concerned about having issue with knock sensors?? I want a little more than PT. I ride the UP of MI so some trails are long and fast. Will I get what I want with this?
10% off right now.
10% off right now.
rnusr01
- Nov 6, 2016
- CT
- 2021 MXZ-XRS 850
Ben, can you run Max Spool 19 and or 20 on pump gas with the 3 bar, TD stock mod muffler and CAI?
Turbo Dynamics
- Jun 16, 2016
- Gatineau
2014 ZR9000 turbo
- YOUTUBE
It should work but we have not done much testing with that combo. Start with Max spool 20 and run a little extra octane if doing long pulls (93 octane+)Ben, can you run Max Spool 19 and or 20 on pump gas with the 3 bar, TD stock mod muffler and CAI?
Turbo Dynamics
- Jun 16, 2016
- Gatineau
2014 ZR9000 turbo
- YOUTUBE
10% off right now.
This combo will work good and make big power close to 270HP. OPtimal fuel for long pulls, aggressive riding is 93, normal riding 91.
Bigblue1
- Nov 29, 2007
- NY
- Sidewinder RTX-LE
Apex SE
I have PT with SQ. How does that compare to Max Spool 16 SM. Very happy with it. Just wondering as I have a little addiction going on.
rnusr01
- Nov 6, 2016
- CT
- 2021 MXZ-XRS 850
How much HP with this combination?
Turbo Dynamics
- Jun 16, 2016
- Gatineau
2014 ZR9000 turbo
- YOUTUBE
Since you have a Super Quiet muffler Your best bet is Max 17 for extra power over powertrail or Max spool 17 if you get a 3 bar map upgrade.I have PT with SQ. How does that compare to Max Spool 16 SM. Very happy with it. Just wondering as I have a little addiction going on.
