20/80
With a lot of talk about how heavy the 4 strokes are which sled would be heavier? the new side winder or a new apex.
yamajammer76
- Apr 6, 2005
- Black Hills, SD
- 2024 Arctic Cat Riot 600 1.75
I don't know the exact difference in weight, but the Apex has to be heavier then a Sidewinder by quite a few pounds.
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
- 2018 Sidewinder RTX
The Apex will win that contest hands down. Its an 'aircraft carrier' of a snowmobile.
MS
MS
20/80
wonder what the weight difference would be? we might be surprised.The Apex will win that contest hands down. Its an 'aircraft carrier' of a snowmobile.
MS
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
If a viper weighs about 525, a SW will weigh a little more - say 575 (max).
An apex weighs in at 650 lbs.
MS
MS
blueironranger
- Feb 3, 2009
- Iron Range MN
- 2014 Viper XTX
2009 Phazer MTX
MS
I believe Yamaha said ~40# heavier than a Viper but I can't see how the turbo system on Sidewinder adds that much weight. And I've seen "official" dry weights around 615 for the Apex so somewhere around 50# lighter for the Winder.
lockburner2000
lockburner2000
lockburner2000
Well it kinda looks like the side winder and apex are not to far apart according to this, Sevey said a apex is around 650 lbs on the real world weights a sindwinder is 671 lbs
lockburner2000
I will say the Polaris wet weight is impressive being also it caries 2.5 gal more fuel the the Doo Doo. From what i can tell.
Riceburner
- Apr 14, 2003
- N.B. Canada eh
- SideWinder LTX 50th
My 2013 Apex SE is 681 lbs wet.
Turbo YamaCats appear to weigh about the same as my Apex SE.
Hmmmm !!!
Hmmmm !!!
20/80
The xtx would weigh a little more wet, but the single shot suspension has some weight savings.My 2013 Apex SE is 681 lbs wet.
Hmmmm !!!
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
Didn't think the SW was that heavy. I stand corrected.
MS
MS
wexfordhunter
- Feb 8, 2009
- Clawson, MI
- 2008 Apex LTX GT
2004 ViperS
- Clawson, MI
Note those are studded. Depending on how many studs and length of them that could vary quite a lot.
- 22K
