rage man
i know everyonee says to run 87 but i just noticed on the side of my se it says 91 but i thought it was all 87
gormleyflyer2002
interesting, got picture
Grimm
I just checked my manual, it recommends minimum of 86 octane fuel...but for Finland and Sweden, 91.
europe has a different way to come up with the octane rating. the octane number will read higher than what our number is. think of it in low, mid and high, octane it is easier. ski
gems4sale
I just checked the xtx it says 91 ron minimum. So I know the Apex ran on regular fuel. I red it and it was 91 ron min as well. I guess I'll start running High Test from now on. I thought the motor was made for regular fuel... I heard High Test burns slower because of the higher octain rating.
2008 Nytro RTX
My manual says to run 87.
Koeckman
As previously stated in the other thread............
Anywhere in North America.....86 or higher
All others (Europe)............91
Right out of the Maintenance Manual.
loudelectronics
My sled says 91 as well. Manual states 87, so I just use 87.
rage man
cool 91 must be the same as 87 in europe
MUDDER
That's right 91 Ron is the same as 87 octane
pistol
Two standards... Euroland uses RON and NA uses R+M. So running 87 in NA is fine. However my question would be what effect ethanol is having in the fuel. I believe the 10% ethanol you find in gas these days leans things out per say. Does that mean we should be running fuels with no ethanol such as Shell V-Power etc????
pistol said:Two standards... Euroland uses RON and NA uses R+M. So running 87 in NA is fine. However my question would be what effect ethanol is having in the fuel. I believe the 10% ethanol you find in gas these days leans things out per say. Does that mean we should be running fuels with no ethanol such as Shell V-Power etc????
I run shell 91 in every sled I have for the simple fact that it has no ethanol,
piece of mind I guess.
pistol
Notice anything negative about running 91? Slower against buds sleds? Less gas milage?
pistol said:Notice anything negative about running 91? Slower against buds sleds? Less gas milage?
Nothing negative about it at all.
pistol
thanks
