87gtNOS
- Nov 30, 2005
- Toronto
- 12 Apex XTX MCX powered
Well, still working on my sled...track is on, studded, chaincase is full of oil, engine oil changed...etc...but still had a couple of issues with a defective part.
So I put on a wideband O2 senser from NGK. Pretty neat unit. It does a count down as it is heating the O2.
Here's a vid of it...as I was unsure of what forum to put this post in...Here or Superchager/Turbos???
*****EDIT - APEX teaser vid # 2!!!!!!*****
http://media.putfile.com/APEX-teaser--2
:exc:
MachZ's
:exc:
MachZ'sRTX Meirda
That is really cool!
I hope it works better than the Stoich guage on our drag car!
87gtNOS
- Nov 30, 2005
- Toronto
RTX Meirda said:That is really cool!
Thanks!!
Did you use a 'wide' band or 'narrow' band?
RTX Meirda
Good question! We installed it 4 years ago and I ignore the thing. It bounces around all over the place. It only does one bank as well.
87gtNOS
- Nov 30, 2005
- Toronto
Yes, I have seen those kind before, constantly revolving back and forth!!RTX Meirda said:Good question! We installed it 4 years ago and I ignore the thing. It bounces around all over the place. It only does one bank as well.
RTX Meirda
Have you gave it a blast on the grass yet?
I think you can learn a lot with a day on the ice and some lowboy valves?
I checked the website, it does not look really pricy?
Can it be mounted without drilling the plastics?
87gtNOS
- Nov 30, 2005
- Toronto
Yes, I made a bracket for $2 worth of metal brackets from Home Depot!! I didn't have to cut anything to install THIS!!!
RTX Meirda
Was it easy to get at the exhaust with the track out?
87gtNOS
- Nov 30, 2005
- Toronto
Yes, the exhaust is easy to take off....take off all that plastic, then the 2 bolts that hold the tank to the tunnel. Then prop up the tank about 6". The 2 inspection plugs are there(runner). 12mm deep socket, loosen the clamps and pull back and up on the muffler. When putting it back on, push it foward till it hits the header pipe, then I pried up with a long crow bar between the track and the pipe. At the same time push foward and it slides right back on.
I guess way easier with the track out...
RTX Meirda
If I do this, may as well do it at the same time as track and plugs.
How much is that unit?
AIRWOLF
Guest
- Oct 1, 2004
- New York
- www.sledpartsgarage.com
and where did you get it
87gtNOS
- Nov 30, 2005
- Toronto
AIRWOLF said:and where did you get it
http://www.ngk.com/afx/
http://www.ngk.com/more_info.asp?AAIA=&pid=20509
JDMCRX
- Dec 13, 2005
- OTTAWA, ONTARIO CANDADA
- www.jbauto.ca
If anyone is intereted in wide bands i can get PLX's for 255 for the round gauge or a M300 for 295ish
87gtNOS
- Nov 30, 2005
- Toronto
Made the new video this weekend...knock sensor is on...the LED is flashing lots, the sensitivity is set too high!!
*****APEX teaser vid # 2!!!!!!*****
