Zakre
radianguy said:Does anyone know if the phazers are the same?
Yes but only if you run into a tree.
Mountaintech
dilligaf said:My oil filter was dented pretty bad, glad I checked. Installed Yamaha oil filter 5DM-13440-00. Its shorter and provides lots of clearance.
The Roest skid plate allows you to run the longer 2 3/4" oil filter and still have adequate clearance. More oil and more filtration.
pauly
Thanks for the tip. I will check mine out.
yox185
Reviving this thread to let you know I checked mine today. The oil filter had no marks on it, but the oil pan had some deep gouges in it from the metal braces. I will be removing the braces and writing a stern letter of disapproval to Mr. Yamaha himself. Does anyone know how to write "Dumb #*$&@" in Japanese?
Mountaintech
yox185 said:Reviving this thread to let you know I checked mine today. The oil filter had no marks on it, but the oil pan had some deep gouges in it from the metal braces. I will be removing the braces and writing a stern letter of disapproval to Mr. Yamaha himself. Does anyone know how to write "Dumb #*$&@" in Japanese?
Are you running an accessory skid plate?
yox185
Roest said:yox185 said:Reviving this thread to let you know I checked mine today. The oil filter had no marks on it, but the oil pan had some deep gouges in it from the metal braces. I will be removing the braces and writing a stern letter of disapproval to Mr. Yamaha himself. Does anyone know how to write "Dumb #*$&@" in Japanese?
Yeah I have the Yamaha plate. I don't do any off trail riding so it works fine for me. That one you are selling looks great, and if I did any off trail it would be on my sled.
rage763
thanks for reviving this thread, i somehow missed this last year (maybe i was riding too much... wait thats impossible
will check it out first thing, thanks again
)will check it out first thing, thanks again
zeke66
Did mine last week. Ground down the 2 center ribs flat. Little peace of mind.
Ruckus
物の言えないろば
Mountaintech
yox185 said:Roest said:yox185 said:Reviving this thread to let you know I checked mine today. The oil filter had no marks on it, but the oil pan had some deep gouges in it from the metal braces. I will be removing the braces and writing a stern letter of disapproval to Mr. Yamaha himself. Does anyone know how to write "Dumb #*$&@" in Japanese?
Thanks. Most of the skidplates I sell are being purchased by trail riders. Here's why they like them.
http://www.ty4stroke.com/viewtopic.php?t=92318
RiceGrinder
Did Yamaha address this issue on the 2010 and 2011's?
Mountaintech
Not for 2010, not sure about 2011. What issue do you mean specifically, the aluminum ribs rubbing, or the total lack of adequate subframe, engine, and front heat exchanger protection?
RiceGrinder
Any of those......Roest said:Not for 2010, not sure about 2011. What issue do you mean specifically, the aluminum ribs rubbing, or the total lack of adequate subframe, engine, and front heat exchanger protection?
Mountaintech
Pretty sure nothing has changed. Even if the ribbing has been modified to alleviate the rubbing issue, you still have the same inadequate plastic panels that do little to protect the sled. Best to invest in a Roest skid plate and be done with it. I may be biased, but it's the truth.
SSX600
- Feb 13, 2010
- Richland Center WI
- 2010 Nytro XTX, 1997 Mtn Max 600, 1998 SSX600, 1975 SM292F, 1987 Inviter
Roest said:Pretty sure nothing has changed. Even if the ribbing has been modified to alleviate the rubbing issue, you still have the same inadequate plastic panels that do little to protect the sled. Best to invest in a Roest skid plate and be done with it. I may be biased, but it's the truth.
Its an awesome product I pu one on my nytro this summer and know if I need to jack up the front end I can just put a floor jack under the sled and just up the front end without any issues. Works great for changing skis or adjusting front shock springs. Its a must for any Nytro.
- 8K
