SnoNinja
aka "Plan B"
- Feb 18, 2015
- Gaylord, Michigan
- 2015 Viper LTX-LE
2016 Vector LE For my Bride
2007 Phazer GT, 136" Stretch.
2002 SXR600 (still own)
1997 SX600 (sold)
1997 XT500 (sold)
2013 Can-Am Maverick 1000XRS
Running 8dn with glide washers, machined for coil bind only. No machining done on primary.Snow ninja you are running the 8dn correct, glide washer's or without, also are your clutches machined for overdrive or just coil bind?
chaleurphantom
- Oct 5, 2009
- Northern New Brunswick, Canada
- 2018 SIDEWINDER LTX-LE 50th Anniversary
2016 VIPER XTX LE - WHITE,
2009 VENTURE GT,
1995 POLARIS INDY 500,
1984 SKI-DOO CITATION 3500
A couple of questions? What are glide washers? What do you mean by machining for coil bind?Running 8dn with glide washers, machined for coil bind only. No machining done on primary.
SnoNinja
aka "Plan B"
- Feb 18, 2015
- Gaylord, Michigan
- 2015 Viper LTX-LE
1997 SX600 (sold)
1997 XT500 (sold)
Glide washers come with the BV kit and go one on each side of primary spring to keep the spring from binding against the aluminum cups. Makes the clutch more efficient. Machining for coil bind is having the secondary cup on the movable sheave cut deeper so that the stock pink secondary spring doesn't coil bind. Wraps on stock pink secondary spring touch each other near full shift causing belt slip, and the secondary can't open all the way. With TP BV Blue spring, machining the secondary is not necessary as that spring has less coils and won't coil bind.A couple of questions? What are glide washers? What do you mean by machining for coil bind?
chaleurphantom
- Oct 5, 2009
2009 VENTURE GT,
Cool. I do have the "black" washers from the kit installed in the Primary and I have the blue spring in the Secondary.Glide washers come with the BV kit and go one on each side of primary spring to keep the spring from binding against the aluminum cups. Makes the clutch more efficient. Machining for coil bind is having the secondary cup on the movable sheave cut deeper so that the stock pink secondary spring doesn't coil bind. Wraps on stock pink secondary spring touch each other near full shift causing belt slip, and the secondary can't open all the way. With TP BV Blue spring, machining the secondary is not necessary as that spring has less coils and won't coil bind.
I switched to the Gates 8DN equivalent. I doubled up on the washers on the Secondary but I have little bit of belt squeal in the primary at idle. I ordered an OSP infinite adjuster for it.
- Apr 14, 2003
- Hessel, Michigan
Well said bud!
- Apr 14, 2003
- Hessel, Michigan
Murdered137,
Shagman and I talked last night and check to see what gearing you have....you might be 21/49 which will give you about 96mph top speed.
Told Shagman to have SnoNinja pull his clutches off this weekend and let you try them...this way we know if it is an issue with your clutches.
Wish I could be there.....
murdered141
Snow Punisher
- Nov 24, 2015
- U.P Michigan
It's a 15 ltx dx, it has what it came with, I thought the rtx/ltx were the same, xtx has different gear's but overall all 3 have same final ratio due to the smaller drivers in the xtx, or so I am told.Murdered137,
Eighty8LE
- Mar 19, 2015
- 15 viper ltx LE
My LTX came with the 21/49 gears because it was an LE with the 1.75 track. I believe you should have the regular 24/50 if you have the DX.
murdered141
Snow Punisher
- Nov 24, 2015
- U.P Michigan
So do I have turd gear's or what?My LTX came with the 21/49 gears because it was an LE with the 1.75 track. I believe you should have the regular 24/50 if you have the DX.
- Apr 14, 2003
- Hessel, Michigan
If murdered has the 24/50, that is a good thing. Going to put SnoNinja's clutches on murdered's sled and see how that works.
Trying to get both you guys running the number.... I brought it up to Shagman last night that the clutches are diecast aluminum and the area where the spider rides is not machined. This would definitely cause a binding issue if the casting twisted from heat or the die was not right to begin with.
My goal is to find another set of clutches, get them working properly and install the Big Venom kit for people to try on TY rides.
- Apr 14, 2003
- Hessel, Michigan
No, you should be able to run right with SnoNinja
Eighty8LE
- Mar 19, 2015
- 15 viper ltx LE
Wish I was closer to you guys so I could try a different clutch. Mine is running pretty much identical to murdereds.
murdered141
Snow Punisher
- Nov 24, 2015
- U.P Michigan
Again I am no speed demon, I like to hit it hard 0-90 or so and let off, but it would be nice to know that my clutches are working properly, and take it to 105 if I ever need to. I don't want to take up anybody's fun time at the ty ride, but greatly appreciate the opportunity, help and everyone's interest to make this viper run.No, you should be able to run right with SnoNinja
shagman
Vendor
- Feb 18, 2014
- Cedarville Michigan
- 2017 Sidewinder BTX LE
2014 SR Viper XTX SE (Sold)
We typically do some clutch testing early in the morning before we head out for the day. You have my phone # if needed. I have to reset my clutches before we head out on saturday so will be out early for sure and snoninja wants to try one of my helix's so he will be out also. While we are doing ours we can check yours also. there is a good spot to run not far from motel.Again I am no speed demon, I like to hit it hard 0-90 or so and let off, but it would be nice to know that my clutches are working properly, and take it to 105 if I ever need to. I don't want to take up anybody's fun time at the ty ride, but greatly appreciate the opportunity, help and everyone's interest to make this viper run.
murdered141
Snow Punisher
- Nov 24, 2015
- U.P Michigan
Hotels are booked solid, might have to come up early Saturday, won't miss it, and thanks to all.We typically do some clutch testing early in the morning before we head out for the day. You have my phone # if needed. I have to reset my clutches before we head out on saturday so will be out early for sure and snoninja wants to try one of my helix's so he will be out also. While we are doing ours we can check yours also. there is a good spot to run not far from motel.
