sledder454
im looking to replace the battery in my nytro. looking for a battery with more CCA then the factory battery (YTX20L-BS) . What battery is everybody running? is there any with more CCA. i looked into the interstate battery but what i found was only 240 cca and i beleive the factory is around 270 cca
sledder454
found this one on ebay 320cca anybody have any experince with it?
http://www.ebay.ca/itm/Battery-YTX20HL- ... d9&vxp=mtr
sledder454
could also go with the yuasa ytx2ohl-bs 310cca
Supa Dexta
Reasoning for more cca's?
If your battery is just old and tired, perhaps a new one will do what you expect anyways, even if it is the same model number.
mx1500
Thats my question, reason for more cca?
Dimebag
- Nov 3, 2009
- Norway, 68N
- www.ty4stroke.com
I just installed my ytz10s with 145 cca. I feel pretty sure even this battery will work in any temp.
sledder454
Had a few times last year when it barely cranked over and once i had to boost it (when it drops below -20). So i thought if im replacing the battery anyways why not get more cca's pretty sure its not going to hurt anything
X3, my cheap 10 has fired my sled at -35. The engine was crabby, the battery wasn't.
clatla
I would agree with the others a new battery would be better than your old one. If I remember correctly last year when I replaced mine with an Interstate there were two options. 270 CCA and 310 CCA.
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
Read up on Odyssey batteries...in your case the PC545 will fit your Nytro. It apparently provides 545 cranking amps for 5 seconds...more than enough to start your sled. A little pricy, but apparently a solid battery...has great reviews on Amazon.com
