akvector
Rode the vector yesterday after doing the updates. I love the glasspack and the tunnel extension. What a difference it does not drag in the snow anymore. I am wondering how I am going to be able to tell if my sled is running to lean after opening up the exhaust. yesterday was great but it was also 30 degreas out. I have already dropped one size in main jets I am just worried when it is 10 out that I may be to lean.
Changes I noticed with the glasspack a whole better fuel mileage that is worth it in it's self. The down fall is that it does not like run on cold start up. I have stay there and work the throttle until it is warm.
Lots of heads turned becuase of the sound. It sounds awesome!!!!
Kachess
I'm not sure what "lean" feels like, but I've felt "rich" at high elevations. I guess you could check the color of your plugs.
akvector
its a four stroke the plugs do not give the indication like a two stroke. I understand it should start to back fire just not sure about that
Trxster
akvector said:its a four stroke the plugs do not give the indication like a two stroke. I understand it should start to back fire just not sure about that
??????Who told you that? We've been reading plugs on cars, bikes, etc for years. PUll your plugs after a long pull. Otherwise, spend the $250 for a wideband and have the certainty.
Rt
akvector
Trxster said:akvector said:its a four stroke the plugs do not give the indication like a two stroke. I understand it should start to back fire just not sure about that
Rt
That would be Hartman and the dealers up here. But if the plugs will tell the story I will definately look. But at 40 degreas it is definately not a concern now
yamahaboy_15
Yah i like the sound and the wieght issue that we have saved on the glass pack. Kachess helped me on that and have not had a problem yet the only problem is your TORS will go off.
richen up your fuel screws it sounds too lean at idle
akvector
yamahaboy_15 said:Yah i like the sound and the wieght issue that we have saved on the glass pack. Kachess helped me on that and have not had a problem yet the only problem is your TORS will go off.
disconnect the tors. Mine did it to me the 1st ride. Disconnected it right after
akvector
pro116 said:richen up your fuel screws it sounds too lean at idle
Hmm will that do it or should I get a bigger pilot jet??
I wold try the fuel screws first they work from idle to about 1/8 throttle and it's free if there's not anought adjustment to clear it up then turn it back where it was and put the pilot jets in.
akvector
My plans are to find my stock jets and jet back up to stock and adjust the fuel screws.
- 24K
