tool to use for cutting tabs off viper windshield
Blueaway
Age
60
Alliston
Canada
2023 srx
Little late, ordered the windshield for my sidewinder in January came in today lol. Just curious what tool you used to trim windshield . Thank you
I used this, might be overkill but it works good. Used a sharp utility knife to clean up the melted plastic on the edges.
Thank you but unfortunately I don't have one of those !!
use masking tape to mark off exactly where you want to cut. heat up a utility knife and it will cut like butter along where you have market out. will leave a nice finish also.
heat up the black trim...pull back.....mask your cut like mentioned...I also used the cut off wheel...but the hot razor knife Im sure would work also...I then used olding adhesive and reapplied the trimlllook closely at the angle as it matches the angle of the hood and looks almost factory
Thank you I got a utility knife I'll try it that way
Thank you Steve for your help
I used a good pair of right and left tin snips and it worked minty! No heat required just don't close the snips on your cut
