660 SilverTip
- Jun 2, 2004
- Alberta Canada
- img78.photobucket.com
- Alberta Canada
- WLM
- tkoconsulting@telus.net
I can't wait until my engine loosens up because I know the power will increase. I mean it has quite a bit now and I have not done any engine mods yet. I have almost flipped it over a few times with a rip on the throttle. The thing pulls heavy loads with ease. Hey? Can anyone tell me if that exhaust end cap mod works or not?
I have spoke with Kevin at Port Washington Yamaha and he said jetting up and changing the needles is req'd to get the most out of the mod. I will try and get more details.
660 SilverTip
- Jun 2, 2004
- Alberta Canada
- Alberta Canada
- WLM
Have you come up with anything yet?
I was hoping Kevin would see this and give us some insight...guess I will have to get a hold of him.
Port-Parts
TY Advertiser
- Sep 18, 2003
- Port Washington Wi
- www.portyamaha.com
- 2012 Nytro RTX
2018 Sidewinder BTX SE
If you remove the end cap and go into the rear of the exhaust there is a plate on the bottom half of the muffler. Guys are drilling 8-10 holes in this plate from the rear to provide a more straight thru exhaust flow. They also modify the end cap outlet to provide more flow. Some have removed the outlet tube completely others have removed it and added a new bigger diameter outlet. Some have done this and left the jetting stock others have went up a size or two on the main. All have reported an increase in performance and claim the machine wheelies much easier. I have only rode a Grizz with 28" tires that had this mod and it definitely seems to accelerate better with this mod.
- 46K
