thunderbolt
Can anybody give me the proper torque spec on the main primary clutch bolt , I believe its a 22 mm head . also the six ten mm head bolts for the cover . Now for the secondary main bolt and the three helix nuts .
And yes Im doing a clutch kit lol
XP123
- Dec 25, 2016
- Chautauqua NY
- Sidewinder XTX LE 137
The primary clutch bolt is 108 ft lbs then loosen nut and torque to 43 Ft lbs. the secondary bolt is also 43 ft lbs.Can anybody give me the proper torque spec on the main primary clutch bolt , I believe its a 22 mm head . also the six ten mm head bolts for the cover . Now for the secondary main bolt and the three helix nuts .
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
Primary bolt torque to 108ft/lbs, loosen and retorque to 43ft/lbs. Secondary torque 43ft/lbs.
thunderbolt
Thats awsome thank you so muchView attachment 133300
stevewithOCD
Yamaha, Make me Come Back
- Jan 1, 2008
- Live CT Ride MAINE
- 900 R
2006 Apex RTX
I had to get another torque wrench to get that primary to 108 pounds.
SHHHHHHH
My boss is still looking for it!
SHHHHHHH
- 46K
