Mark Andolina
- Jan 4, 2018
- Buffalo NY
- 2007 Yamaha Phazer
Is there any way I can adjust between Soft - Medium - Hard settings on the torsion springs, without removing the skid? 2007 Phazer
Cubby
- Dec 14, 2009
- South of Winnipeg, Manitoba CANADA
- 2015 Ski Doo 900 ACE Renegade Adrenaline
2007 Yamaha Phazer GT
Yes - there is a big nut on the torsion block that you use to change to the different side.
Mark Andolina
- Jan 4, 2018
- Buffalo NY
Gone Blue
- Oct 11, 2006
- Howell, Michigan
You should be able to turn the torsion block with the skid in the air or without the weight of the sled on it. G.B.
Mark Andolina
- Jan 4, 2018
- Buffalo NY
thanks for the response GB.
I would need to take the "long" tail of the spring out of the block near the rail then correct? If I did that, rotated the block re-installing the "short" tail of the spring in the block under the adjustment I want, I feel like it would be very hard getting the long tail back into the block near the rail..
I just have not tried yet and am trying to get a game plan together before I jumble something up.
sgauthier
- Mar 5, 2009
- southwest, Ontario
- 2011 Apex XTX
You just put a wrench on it and spin it , that easy. Do one side and then do the other side and make sure you have it in the same place. You don't take anything off. There should be a wrench in the tool kit big enough. you don't need to lift the rear up for the ground but it will make it easier, just be careful when spinning the wrench so you don't pinch your fingers or knuckles. Like you said it's under tension.
Mark Andolina
- Jan 4, 2018
- Buffalo NY
Well I got one, but figured out why the previous owner never adjusted the other side..that nut is completely stripped round.
Any idea on how I can turn that without using the nut. Tried a couple vice grips and man it’s not eve budging.
the way you described is how i do them when i do not want to haul out the wrenches. i just tip to one side then the other to do it.
Mark Andolina
- Jan 4, 2018
- Buffalo NY
Take the long tail out, adjust and then bend long tail back up in the rail block?
Gotta be a pain with all that tension on there but I’ll sure try
yup. that is how i do it trailside. at home i will use a pry bar or a couple of foot long peice of wood.
Mark Andolina
- Jan 4, 2018
- Buffalo NY
Perfect thanks Maim, I appreciate the feedback.
Snowmixer
- Oct 29, 2010
- Snohomish, Washington
- 2007 Phazer Mountain Lite
2008 Phazer MTX
2012 Arctic Cat M800 153
Just in case you really want to adjust that stripped one, or make adjustments frequently without worrying about stripping the other, there are billet aluminum versions available. I know Yamaha sells one and likely a few other companies as well.
- 7K
