DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
Just wondering if I'm missing something but I installed my secondary adjuster and when you turn in the Allen bolt to open the secondary it wears into the helix. Am I missing a washer or something?
IH8CROWS
- Jan 19, 2009
- Wisconsin
- 11 Apex
16 Apex
I just slide a small 1x2 piece of metal in between the screw and the helix before I start turning it in.
Then it chews into the metal and not the helix.
DMCTurbo
- Nov 12, 2005
Ya I can do that too.... Are the other manufacturers the same?I just slide a small 1x2 piece of metal in between the screw and the helix before I start turning it in.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
On the OSP they have a black plastic spacer, so screw does not touch helix ever.
But you can clean up the end of the screw nicely, grind and smooth ect, so it wont do too much damage each time.
Lots of previous discussion here: https://ty4stroke.com/threads/secondary-belt-adjuster-and-belt-remover.149335/
DMCTurbo
- Nov 12, 2005
My bad
should have searched first...On the OSP they have a black plastic spacer, so screw does not touch helix ever.
