K-fab
- Apr 1, 2006
- Scottsdale, AZ
- www.yellowdogracing.com
- The Mini-Raptor, a Yamaha Nytro powered off road truck.
- out in the desert somewhere
I need some help, as I can't find the info in the service manual.
Page 4-56, part number 7 - Front Axle Assembly. I need to know the diameter of the wheels and how thick the track on the sled is. (not width, but thickness of the track - have to add that (twice) to the diam of the wheel to get the correct overall diameter of the drive.)
I have a Phazer engine (man, sweet little power plant!) in an off road car and I haven't hooked up the speedo completely and it pisses off the dash unit (I get a code 42).
If I can get the diameter of the drive axle from the sled, I can work backwards and calibrate the speedo pickup to work with my car.
Thanks in advance.
Thanks in advance.
Wheels are 7in and track with lugs is about a inch.Without lugs it is .233thick.
Very cool project!I tried convincing some guys building one of those ASE formula cars to use a Phazer motor but they had other ideas.Let us know how it goes.
K-fab
- Apr 1, 2006
- Scottsdale, AZ
Thanks for the info - it's exactly what I needed.
I can now figure out how many "teeth" I need to cut into the edge of my brake rotor so the speedo sensor is calibrated, more or less.
looking4speed
You can read about that car and others he has on WWW.Minibuggy.net.
