MikeWalters
- Feb 21, 2010
- Saskatchewan
- 2007 Phazer
Does anyone know how to check for proper track tension?
I think mine is a little tight but am not sure what to reference??
- Nov 1, 2009
- Winnipeg, Manitoba
- 2009 Phazer RTX
something about hanging a weight and measuing how much it drops down. i just eye ball it by pushing down on the inside of the track and seeing how much it drops down by.
3wheelerdude
- Jan 6, 2010
- Ottawa Ontario
- 2019 Voyageur 600
2019 ZR200
1991 Ovation 340
1986 XLV 540
Previous sleds: 1996 Vmax600, 2007 Phazer, 2016 Bearcat 3000
This is how I do it. (Not a professional here, but its worked for me for many years).
- Lift rear of sled off the ground.
- Drop 10 pounds of weight between the rails, on the track.
- Insert 2 fingers between track and rails.
- Tighten adjusters until fingers touch the rail.
- Repeat on other side.
I adjust mine so loose that it ratchets especially coming off the driveway into the ditch and pinning it when it hits.I then adjust by 1/2 a turn each time till ratcheting stops.
blueironranger
- Feb 3, 2009
- Iron Range MN
- 2014 Viper XTX
2009 Phazer MTX
+1 this usually ends up being more than 1" of slack with no weight hanging off the track. Looser the better!cannondale27 said:I adjust mine so loose that it ratchets especially coming off the driveway into the ditch and pinning it when it hits.I then adjust by 1/2 a turn each time till ratcheting stops.
MikeWalters
- Feb 21, 2010
- Saskatchewan
- 2007 Phazer
Thanks guys!
I guess what I'd like to know is what are the ill effects of a tight track?
- Nov 1, 2009
- 2009 Phazer RTX
I would assume Hifax wear would be one of them
Yes.Not sure if it helps speed but I think it helps traction by ballooning more.Has to be easier on Bogeys also.
3wheelerdude
- Jan 6, 2010
- Ottawa Ontario
- 2019 Voyageur 600
2019 ZR200
1991 Ovation 340
1986 XLV 540
Too tight is bad for eveything in the skid. From shocks to slides.
Too loose is bad for the track and possibly the heat exchanger if you run studs.
marpolsdofer
I just got some wights and put them in the track or you could use a fish scale.
Vmax540
- Jul 25, 2005
- Clarion Pa.
- www.vintagevmax.com
blueironranger said:+1 this usually ends up being more than 1" of slack with no weight hanging off the track. Looser the better!cannondale27 said:I adjust mine so loose that it ratchets especially coming off the driveway into the ditch and pinning it when it hits.I then adjust by 1/2 a turn each time till ratcheting stops.
Agreed ! Just watch your studs !
QUADSCRIB
Mine ratchets when loose in ANY way.
spike337
Just adjusted mine yesterday. It's hard for me to go so loose from the track guide days where you would over-tighten.
I set it so while on the stand, it'll just be on the verge of rolling on its own at idle. This is very easy, BUT, i'm not sure if it's the best way? Works for me. Anyone else try this? Anyone else have theirs 'set' want to try and see? I'd be very interested if my way gives you a good tension.
That should be just fine and makes sense.But dont forget a cold track does not roll as easy as a warm one.
